Home > Maintenance & Modifications > Coil springs part numbers?
bear100
Hey all, can you help with the part numbers for front and rear coil springs for my Defender it’s a mine field!
I have a 2010 2.4 Puma utility and want to put on a new set of genuine springs all round on.
My Fox shocks should be arriving from Paddocks Wednesday and would rather fit both the same time for obvs reason but with so many part numbers I don’t know what to order and from where?
They are for my overland build which is now nearing completion Very Happy
The plan is to use the air lift bags to help when heavily laden 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #831657 17th May 2020 7:57pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
And to hijack a thread if thats ok I am sort of in the same boat.
I have a 1998 300TDI, 2 seat utility, WA chassis number so the last before the XA ones come out.
For the life of me I cant find what springs to put on? I have got the shocks and supporting hardware sorted, just need to know what OEM springs to put on?
I have used the search function and still no closer to what I need?
Sorry if I have derailed this thread, more than happy to start a new one if needed.
TIA
Post #831698 18th May 2020 1:20am
bear100
No Worries, i just can't seem to make sense of the vast array of different ones out there
I did want the Alive comfort Standard height but they are not advertised on their website site and no reply to enquiries so the best way forward is another set of Genuine 2023 Defender L663 V8
Post #831715 18th May 2020 7:27am
Front coil springs are REB500220, colour code Blue/Yellow, which now appears to be the standard front spring for all Puma models.
Rear springs for a 110 USW are RKB101111, colour code Brown/Purple. Darren
Post #831717 18th May 2020 7:33am
camelman
Post #831718 18th May 2020 7:34am
Danny Fireblade
Thank you to all. I thought it was those however they said from chassis XA onwards and couldn't find anything for pre XA?
Thanks everyone Thumbs Up
Post #831719 18th May 2020 7:41am
Front drivers side, NRC9446, Green
Front passenger side, NRC9447, Blue
Rear drivers side, RKB101230, Yellow/Red
Rear passenger side, RKB101240, Yellow/White
These are the standard duty springs. There are also HD versions available.
https://www.lrworkshop.com/diagrams/land-r...ings_52610 Darren
Post #831720 18th May 2020 7:44am
bear100
Thank you very much! Bow down
So many coils out there and so many bad stories, genuine is a lot less hassle
Thumbs Up 2023 Defender L663 V8
Post #831753 18th May 2020 10:30am
camelman
I believe The Utility has the HD springs as opposed to the standard? Mine has the brown/purple on the rear
Post #831755 18th May 2020 10:31am
You could be right. For some unknown reason, I thought that Danny had a 90 and have given the details for that Rolling Eyes Darren
Post #831760 18th May 2020 10:42am
Danny Fireblade
Thanks chaps. Looks like I will be trying to find a set of the Brown/Purple.
Any ones to avoid or recommendations of suppliers etc?
Post #831767 18th May 2020 11:33am
Depends how much you want to pay. Genuine here:
https://rimmerbros.com/Item--i-RKB101111
Or pattern ones for a lot less:
https://paddockspares.com/rkb101111-spring-road.html
I've even got a pair of used (approx. 54k miles) ones in the garage that you can have for free, if you want to come and get them. Darren
Post #831776 18th May 2020 12:19pm
MartinK
They are all here: https://www.defender2.net/forum/topic13312-15.html
or here: http://bilashakaflowers.com/LandroverSprings.htm
Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #831785 18th May 2020 1:18pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
lrsurplus on eBay have new take off springs listed.
You send them a message with the colour code you require and they’ll get back to you.
I bought new front and rear sets off them a couple of months ago, but......they were £50 a pair then, now they are £125 a pair! Still a saving on new genuine parts though I guess.
https://www.ebay.co.uk/itm/143556653678 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #831804 18th May 2020 3:26pm
Danny Fireblade
So just to confuse matters I have cleaned off my nearside spring and its RED/GREEN.
I am guessing Brown/Purple will still be ok?
Post #831807 18th May 2020 3:28pm
