Home > Maintenance & Modifications > Primer Colour Advice
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I've rubbed down some corrosion patches, then used Upol acid etch primer in grey with several coats of land rover Firenze red on top. The patches stand out as a lot lighter than the surrounding paint work.
I'm wondering if I should have used a darker primer. Anyone got any ideas?
- Thanks
Post #831379 16th May 2020 10:53am
Bluest
Red is the worst colour for fading. Could it be you new colour is correct, but the rest had lightened with age?
ETA Just read the new is lighter, so forget that. I’ll get my coat Thumbs Up 2007 110 TDCi Station Wagon XS
Post #831380 16th May 2020 11:01am
JPE
Thanks, yes the new appears lighter. I tried layering quite a few coats expecting it to darken, but I can see the outline of the primed area. I'm leaving it to thoroughly dry for now. I've yet to sand the paint or apply the lacquer. I'm hoping to avoid having to take it to a professional & having to explain what I've done. Smile
Post #831382 16th May 2020 11:06am
Grouse
If you are patch spraying a panel - it will be extremely Difficult to blend the red in without seeing any difference - probably best to spray the whole panel - dark colours are easier to blend in 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #831393 16th May 2020 1:11pm
deftd5
United Kingdom 2005 Defender 90 Td5 XS CSW Cairns Blue
Unfortunately firenze red has very poor opacity. sand and add more coats you'll get there in the end.
You could have used a darker primer but then you would have had a problem with a dark patch showing through.
Post #831421 16th May 2020 5:03pm
JPE
Thanks, I sanded it and put lots of coats on. It got a bit better but I could still see the patches. After adding the laquer layers & polishing & putting the number plate and ladder back on I decided it doesn't really show too much & besides its a defender.
Post #831444 16th May 2020 6:39pm
