Home > Puma (Tdci) > TDCi Autobox
Page 1 of 3 123>
trailbear
TDCi Autobox
Gents
My vehicle ( 2014 110 CSW ) is very shortly going to Ashcrofts ( Easing of Lockdown Permitting ) for fitting of their autobox conversion. The vehicle doesn’t have but will shortly have Cruise Control fitted. I forgot to ask if Cruise Control will be an issue for the autobox as in will it still operate as normal?
Also will the fitment of 18 inch wheels have an effect on the speedometer reading and if so is the way to get round it by fitment of the Speedohealer that I see advertised?
These are questions that I should have asked Ashcrofts but I admit that I did forget to ask the Questions at the time.
Any advice is appreciated.
Regards
Post #831319 15th May 2020 11:08pm
I can't help with the cruise control question but your wheels shouldn't matter as long as they're fitted with appropriately sized tyres. It's the combination of the two that determines whether your speedo will be out or not. Darren
Post #831323 15th May 2020 11:57pm
trailbear
So if the vehicle were to be fitted with 265/65r18 would that present a problem?
Post #831332 16th May 2020 6:30am
No, as that tyre is, as near as makes no difference, the same diameter as a stock 235/85 r16. Darren
Post #831340 16th May 2020 7:35am
trailbear
Thanks, I appreciate the advice. I have said it before that there is pretty much always somebody
With the right answerđź‘Ť
David
Post #831348 16th May 2020 7:57am
Martin
Site Admin
The cruise system on a Puma is aftermarket and so independent on the gearbox, it effectively emulates the pedal.
With an auto box conversion what you wouldn’t have any more is the safety system where the cruise disengages when the clutch pedal is pressed on a manual box (during gear changes).
However as your pedal input doesn’t change during auto box shifts then the aftermarket cruise should work fine.
As above, it’s not the wheel size which determines the speedo reading, it’s the tyre circumference/“rolling radius”. Typical 18” tyres used on Defenders are the same circumference as the factory fit 235/85R16 or 750r16 tyres.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #831365 16th May 2020 8:58am
DAZ110
When I fitted BFG 265/65r18 tyres it made my speedo more accurate.
Post #831366 16th May 2020 9:01am
trailbear
Thanks Gents
That is reassuring that the cruise control will still work, It was something that I hadn’t really
Considered when deciding on the conversion. Also glad that the larger wheel choice won’t cause
speedo reading problems.
Post #831369 16th May 2020 9:18am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Most standard Defender speedos over-read. A number of years ago I used to work with police vehicles and spent a bit of time calibrating different speedos for one reason and another and my recollection is that the law says that a speedo can over-read but not under-read so most manufacturers tend to err on the side of caution and go for a few percent over.
I have never calibrated my Puma speedo but the older Defenders are over by anything up to 10%, which means that fitting slightly larger tyres (which tends to be what people do) simply reduces the error a bit, making it more accurate. If the speedo is calibrated for a standard 32"ish tyre like a 235/85R16, you'd probably have to go to 35" tyres before it would under-read. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #831408 16th May 2020 3:50pm
Virtually every vehicle on the road will have a speedometer which over-reads, and there is a very simple reason for this.
Speedometers are by law allowed to over-read by up to 10% but are not allowed to under-read at all. Since it is inherently very difficult to guarantee that a speedometer is spot on (and for 'difficult' read 'expensive') most instruments are designed to be accurate plus or minus 5%, which is relatively easy and inexpensive. However in order for them then to be legal, i.e., to guarantee that it won't end up under-reading, they are actually designed to over-read by 5%.
Factor in the +/-5% tolerance and the speed will be 0% under to 10% over, i.e., a speedo at the -5% end of the tolerance band ends still cannot display a lower speed that the vehicle is doing.
The design must also allow for all the other factors that can cause inaccuracy, such as tyre wear, pressure and size, so it is perhaps understandable that manufacturers err on the side of caution.
Post #831428 16th May 2020 5:32pm
trailbear
Gents
Thanks for the information, that’s what I like about the forum, everyday is a school day👍
Regards
David
Post #831442 16th May 2020 6:34pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Id like to know how you get on with the auto conversion, as ive been toying with the idea also.
Post #831991 19th May 2020 2:48pm
trailbear
I’ll let you know once it’s done. Certainly haven’t heard or read of anyone having a negative reaction when fitted.
It will be a long trek to Ashcrofts for me but I would much rather go to original designer of the conversion than elsewhere.
There will always be those that say it’s not worth it, you’ll never get your money back but for me it’s about choice, I’ve had my other one for 15yrs so I think I can justify the decision.
Post #832054 19th May 2020 7:48pm
nicks
I have the same thoughts as you then, it’s not all about the cost, more the driving experience. I take mine to Provence at least once a year.
How long will Ashcroft have it for?
Post #832205 20th May 2020 1:46pm
trailbear
Ashcrofts have said that they need the vehicle for between 7 to 10 days to enable them to give it a proper shakedown after fitting and I am more than happy with that.
I agree it is about the driving experience, having only recently been a convert to the automatic transmission driving experience, I wonder why I didn’t consider it sooner.
I am amazed the number of people who still say to me that it is a lazy way to drive, well in that case I am lazy and I can live with thatđź‘Ť
Post #832270 20th May 2020 7:22pm
Page 1 of 3 123>
