Home > Maintenance & Modifications > help with windscreen washers please ?
NCTT
i have an 07 puma and the little nozzle that squirts the water onto the windscreen seems to have snapped.
my question is ,. is this easy to replace ? and what is this thingy actually called
many thanks for any help in advance
Post #8310 11th Mar 2009 10:57am
Grockle
It's held in place by two 10 mill nuts through the bulkhead,I think you'll have to take the dash out, unlike TD5's were you could get to the nuts through the ashtray.I should think it's called the front same as the rear washer jet mounting. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #8311 11th Mar 2009 11:18am
110SEB
Super glue until next visit to the dealers and it'll be covered under warranty.
Post #8312 11th Mar 2009 11:29am
NCTT
RE WASHERS
lovley job cheers fellas
Post #8314 11th Mar 2009 12:25pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
This has been a perenial problem for TD5's as well.
I now smear grease around the washer to stop water getting behind it, freezing, then expanding and snapping the the unit off.
Since I have been doing that I haven't had a failure.
Post #8316 11th Mar 2009 1:16pm
