![]() | Home > Td5 > Fuel & Temp gauge not reading correctly...earth fault? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6640 ![]() ![]() ![]() |
Relays should get slightly warm in use, they use power in the coil to keep the contacts closed.
As the coolant gauge signal comes from and the pedal goes to the ECU, I would be looking at the ECU earth. There is a single ring terminal but it then splits 4 ways to 4 pins on the black ECU connector (pins 1, 2, 24, 25). So check the ring terminals near the seat box, I would be removing them, cleaning the stud and the ring and refitting ![]() ![]() ![]() |
Perhaps also look to add a new dedicated ground wire between the battery negative and the ECU ground stud, as at the moment it relies on earthing through the seat box. You can do this temporarily to see if it makes a difference
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
I will double check them. It might be worth me crimping a new ring terminal on? The others have been corroded inside the wire etc or poorly crimped. Is there a wire in the loom which has no insulation on? I noted one coming out of the grommet then it has insulation on at the plug. I have a ECU extension harness going to the ECU Mounted inside the headlining on the roof. Hopefully I can get this reliable and my confidence will return. Hoping to put the roof tent on and use it for what it's designed for. Thank you again for your help Martin. ![]() |
Uninsulated wire may be the crank sensor shield drain, which pin does it go to?
Good Morning Martin,
I believe it's pin 16. Bare wire with a small section of Back insulation where cable meets plug. Just double checking the earths. Both look good and crimped securely attached to separate posts not together. |
Yes it's the crank sensor screen, that's normal.
I would run a new temporary earth lead direct from the battery negative post to the earth stud(s) - perhaps one stud at a time - and see if that makes a difference. There might be a poor earth path between the stud and the battery. ![]() ![]() |
I will try making a earth extension up and see what happens.
Thank you ![]() |
Good afternoon Martin, What thickness of wire would you suggest. I only have 1.5mm here so think I will get some thicker posted in. One wire looks alot thicker? Not sure what you suggest? Thank you. |
1.5mm2 will be fine, if you are worried run 2 of them in parallel
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
Just to update as Ray has also experienced this.
I put two earths from the negative pole of my battery to each earth post and a bonding strap linking the earth posts under the seat. This cured the problem. It now starts instantly and gauges read correct....well fuel does it's own thing but gives a good clue ![]() Thanks to Martin's advice! I was convinced earth was good as terminals clean etc. I also replaced all relays etc. I'm glad I did all relays as they are definitely a weak point once corrosion and age set it. I pushed the earth through the existing grommets so it looks neat. |
