Home > Puma (Tdci) > Wobbly steering wheel?
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Hi all, I wonder if anyone can help. I have a 2011 2.4 Puma and I've got a bit of a wobble on the steering wheel. There is no issue with the steering itself, at any speed, it's just that when I'm stationary I can grip the wheel at the quarter to three or half past twelve positions and rock it from side to side and get, maybe up to 5mm play - almost like it's loose on the steering column - except that it isn't. If it makes any difference, it's a 14" momo, not the stock wheel. I've only noticed this recently, which leads me to believe something in the steering column is loose.
Any ideas where to start would be appreciated.
Thanks
Post #831052 14th May 2020 1:29pm
Co1
I don’t think that is an issue at all. Try pumping up the tyres a bit and see if it goes away.
Post #831073 14th May 2020 4:48pm
JoolsB
I'll give it a go, cheers.
Post #831088 14th May 2020 5:27pm
Do you mean that you can rock it back and forth as through you were steering, or back and forth as in towards you and away from you?
If the former you may just be feeling the slack that is needed to operate that power assistance valves in the box. If the latter you have a serious problem!
Post #831098 14th May 2020 5:42pm
JoolsB
Shocked It's the latter and it works side to side too - if I didn't know better, I would say that it feels like the steering wheel isn't fully set on the splines. Like I say there's only a few mm of movement and steering response at any and all speeds and under load is fine. I'm not sure if this is a recent development although I think I would have noticed it previously if it was there.
I'm going to be home tomorrow so will have a chance to get at it and have a proper look - if anyone could tell me what I'm looking for - over and above the obvious.
Post #831177 15th May 2020 8:02am
OK, that is serious and needs sorting as a matter of priority and before you drive it.
First step is to remove the centre cap or pad from the steering wheel (it should just pry out carefully) to expose the nut at the top of the column. Then waggle the wheel and see if the wheel is moving relative to the nut. You may find that it is worth putting a finger over the nuts and wheel since it is often possible to feel movement you cant see.
If you're luck, you will fine that this is where the movement is, in which case tightening the nuts will probably fix it. Even if you can't see or fell movement, check that the nut is tight (not crazy tight since the wheel actually sits on a taper, but firmly tight).
If the wheel is solid on the column, as established by the above, then it is most likely that the top bearing in the column has failed. This unfortunately is a bigger repair since as far as I know the bearing cannot be replaced on its own and the upper column is likely to need renewing. I would suggest doing the test above first, then reporting back to this thread with the result, then we'll either celebrate with you if you've fixed it or offer further guidance if you haven't!
Hope this helps.
Post #831180 15th May 2020 8:19am
JoolsB
Righto, better have a look then. Cheers, will let you know how it goes.
Post #831186 15th May 2020 8:40am
JoolsB
Well, after all that, it was the nut on the splined shaft that had loosened a little bit.
Many thanks Blackwolf - I was happily assuming that the fixing nut couldn't be loose because when I put it on, I had properly tightened it.
Valuable lesson - don't assume just because you tightened the Censored out of something on a Defender, it will remain tight!
Post #831205 15th May 2020 10:57am
I'm glad it was the cheap solution, not the expensive one!
Post #831212 15th May 2020 11:55am
Co1
Yep, by far the best result you could have hoped for!!
Post #831223 15th May 2020 12:53pm
JoolsB
Great, more money to spend on bits that I don't need then Thumbs Up
Post #831236 15th May 2020 1:58pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Is there a recommended torque for the steering wheel nut?
Post #831247 15th May 2020 3:15pm
JoolsB
Given my experience, I've just gone for FT Whistle
Post #831257 15th May 2020 4:27pm
Naks
Also check the Panhard Rod and bushes Thumbs Up --
Post #831259 15th May 2020 4:37pm
