![]() | Home > Maintenance & Modifications > Fuel filler fixings help please - 300tdi |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
I think they’re actually a BA thread for some reason, mine were anyway. I replaced with M5 or M6 panhead screws if I recall correctly.
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1882 ![]() ![]() |
You could be correct looking at this, https://www.ebay.co.uk/itm/Fuel-Filler-Nec...Sw9~xeuTrU but I'm not a purist so might try to save a few quid and find something a bit cheaper
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2315 ![]() ![]() ![]() |
So that'll be 2BA then if M5 sized.
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 76 ![]() ![]() ![]() |
I’ve only ever seen pozi screws on 300tdi’s. I replace them with m5x20 pozi screws which are readily available and even stainless if you want.
Great thanks, I ordered these this morning so hope all will be well
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
The originals are 2BA slotted head 77941, with nuts RTC608.
2BA is 4.70mm major diameter, so as above can be replaced with your choice of M5. Wouldn't recommended stainless without isolating from the panel. ![]() ![]() |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
Just replaced the same on the red zepplin a quick tip put anti seize on the back of the new ones will pay dividends if you need to remove in the future
![]() My sky lantern petition http://chng.it/HJXmZC47 |
