Home > Maintenance & Modifications > What size torque wrench do people recommend?
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
What size torque wrench do people recommend? This will be the length and the rating as I suspect you will need different ones for different areas?
If you could say why you need each one that would be good as I am looking at what I need for the first jobs (swivel housing and brake calipers)
Many thanks
Mick
Post #830593 12th May 2020 7:43am
JOW240725
If I could add to this... What's a decent make at reasonable price? I bought one rated up to 180-190NM and broke it torquing to 130NM! James
Instagram @suffolk_rovers
Post #830616 12th May 2020 9:47am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I use a combination of a Norbar 3/8" 10-50nm and a Teng 1/2" 40 - 210nm, they have covered everything LR related so far and lasted well over 10 years.
Halfords torque wrenches seem to get very good reviews also Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #830631 12th May 2020 10:27am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The Halfords wrenches I believe are made by Norbar - I have two and am contemplating another.
Good deal if you can get the trade card discount but not too bad without.
I would recommend Halfords - the:
60nm - 300nm - this is fairly long (if you need exact length I can measure it up and post) and 1/2" drive
20nm - 100nm - this is about 13 inches and 1.2" drive. You can use socket adaptors on wither though
I actually have the 300nm one and a 12nm-60nm one but believe the 20nm to 100nm would be more useful.
Post #830632 12th May 2020 10:30am
discomog
I have two Britool torque wrenches, EVT1200 and EVT3000. I have had them over 30 years and have given excellent service. I had them calibrated a couple of years ago and they were still within tolerance. I'd thoroughly recommend them but they are expensive so if replacing now I would probably go for Norbar/Halfords. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #830653 12th May 2020 11:42am
Hufflepuff
I use a trio of Clarke digital torque wrenches, after watching a review of how much more accurate a digital torque wrench is than a mechanical one.
They are a little bit of a faff to set, but you can save 5 different values so if you only use 5 settings it becomes very easy. They also have a mode where it saves the torque you actually used, ie. beyond what you specified when the beeper went off. Another useful feature is being able to see an instantaneous readout of the current torque, so you know how close you are getting.
Downsides are setting the values (although this is not really any harder than with a mechanical version), removing the batteries from it when not in use (as I don't know how long it would be until the next use - could be months), and that the maximum torque setting of the 1/2" drive version is only 200nm - the later type stub axle nut needs to go up to 210nm. 2005 Td5 90 XS
1989 V8 110 CSW
Post #830656 12th May 2020 11:58am
I have a Sealey 1/4” electronic torque screwdriver. Draper 1/4” 3/8” and 1/2” manual torque wrenches. I tend to use the 1/2” the least and the 3/8” most. The torque ranges are an important factor too. I have found these cover the vast majority of torque specs required. And I’m the costs I’ve saved by having then has paid for themselves and some so in effect free tools. WeWillWin🇬🇧🇺🇸
Post #830657 12th May 2020 12:07pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I can vouch for Teng and Halfords. Really impressed with all of the Halfords professional tools.
Post #830658 12th May 2020 12:07pm
excossack
I've ended up with 3. Halfords up to 210nm I think and two smaller ones. One is from Machine Mart and the other not sure.
Halfords one I like 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #830699 12th May 2020 4:08pm
By preference for me, Britool. I think that I now have about seven, from a 1/4" drive about the size of a chunky pencil up to a 1" drive about five feet long. I do however work on a lot of things that are not Defenders.
My advice is that you figure out what you're going to want to torque down to understand the range you need, then look for a decent wrench that covers your required range in the centre 80% or so of the wrench's range (wrenches don't work so well at their extremities of range).
Bear in mind that relatively few things on a Defender actually need to be done up with a torque wrench, a healthy dose of common sense is generally all that is needed. There are exceptions, typically where multiple fasteners need to be torqued down evenly. Things like stretch bolts must be torqued down, and for these you will probably need an angular torque gauge as well as a torque wrench (TD5 flywheel is an example). However, the fact that the manual specifies a torque figure doesn't necessarily means that it matters, and I do suspect that it has more to do with the increasing level of stupidity and decreasing levels of common sense that seems to have come with the change from dealers having "mechanics" to having "technicians". The fancier the name, the less the skill, or so it would appear.
Post #830741 12th May 2020 7:04pm
Mossberg
I tend to find if anything I overtighten things. I daresay that as I experience different jobs (with a torque wrench) I will start to understand when to stop swinging!
I have not really done much spanner work. Fabrication has been my way. Time to learn!
I hope to get the truck to a decent standard and maintain it. Not worried about looks, but I want it to run well. I have had it about 2 months and not managed to do anything to it. I have had work for the first time in ages, just as the nice weather kicks in - though it did give me the money to buy the truck!
I have an old Norbar torque wrench, but it has been sat at half torque for about 20 years! I need to test it to see if is working right. I have seen how to test it on the internet but don't know how to calibrate it.
I am trying to get my gear together before I get stuck into the jobs. I don't want to start something and not have the stuff to finish it.
Post #830765 12th May 2020 8:24pm
