Home > Td5 > Coolant plug leak
isacs
Coolant plug leak
Having changed my exhaust manifold, I’ve noticed there was some water coming out the coolant plug in the head. Has anyone experienced this? Or is it a trait of not running for the best part of 5 weeks?
Post #829442 5th May 2020 10:40pm
landy andy
Yes had this with my first Td5. Removed it and fitted new plug. Was fine after that.
Post #829446 5th May 2020 11:06pm
It's a very common Td5 problem.
Post #829455 6th May 2020 7:17am
roel
Time to replace it. I know off some td5's of which a plug failed on the highway and that was the end off the engine. Roel
2003 90 Td5 (2009-now)
Post #829534 6th May 2020 6:00pm
isacs
Can I just remove it and apply sealing compound and refit?
Post #830380 10th May 2020 9:59pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Yes, you might find the bung is loose? When I swapped my cylinder head with a new one due to coolant loss I noticed this was loose.
I would use Loctite 572 if you don’t mind spending some money or even some PTFE tape and tighten as a cheaper option.
Steve
Post #830396 11th May 2020 12:15am
apachecow
1999 Defender 110 Td5 CSW Rutland Red
It's a sub £15 part - I'd personally replace with a new one - as has been said, failure can be catastrophic.
LCM100170 is the part number
Post #830401 11th May 2020 12:55am
isacs
I’ve found the plug online but it’s just a plain plug, so I’m still going to have to use some form of sealant before I fit it, so why replace it when it’s the seal that’s gone? Agreed it’s all of £15 but In 20 years of being a heating engineer I’ve never seen a plug fail only the seals
Post #830475 11th May 2020 3:37pm
