Home > Maintenance & Modifications > 1993 Defender swivel replacement |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
I've just gone through this daunting process myself Mossberg. I would recommend watching a series of video's from Chris at Trailor Fitter on YouTube, ie. the set starting at:
https://www.youtube.com/playlist?list=PLLB...d0LZuaU1cY so you know the process to strip the axle down to the swivels. There are several types of 'kit' for the swivels, depending on: (a) Roller bearing top and bottom mounts on the swivel (b) Railko bush top mount (c) If you have ABS or not the kits having codes such as: SSL03F Mid type: https://www.advancedfactors.co.uk/ssk03f-s...5237-p.asp SSK04F Later type: https://www.advancedfactors.co.uk/ssk04f-s...5230-p.asp I'm not sure what a 1993 defender would be, possibly the earlier type than these for which I don't have a kit code. While stripping the axle, you may also want to consider: (a) New wheel bearings (b) Potentially a new stub axle depending on condition (c) Complete set of oil seals However you can just 'hack it' and remove the whole assembly in one piece at the swivel ball flanges, as Mike demonstrated here: https://www.youtube.com/watch?v=XHX1V2FnNk4 Also don't forget to get some decent high strength Loctite (eg. 270) before you start, many of the bolts need to be Loctited on. I managed it (with a lot of prior research!) and I am by no means a great mechanic, so it is possible, but there is quite a lot to it if you've not done it before. 2005 Td5 90 XS 1989 V8 110 CSW |
8th May 2020 10:31am |
To answer your questions directly - there are plenty of choices other than Britpart branded, although from what I gather the Britpart Teflon swivels aren't too bad.
As far as I am aware Britpart don't manufacture anything themselves, so you could find no matter who the brand its been churned out of the same factory. I bought one kit from https://www.shop4autoparts.net/parts/axle-...abs-ssk04/ which unfortunately came with the earlier type Railko bush swivel on one side, which I am still in discussions with them about replacing. I then failed to spot the 'kit' on Advanced Factors and bought all the parts individually which cost quite a bit more (about £140 total, although they have a Covid discount atm which reduced it to £120), and the Swivel came in a Bearmach branded box. As to if you need one shot grease or not - the answer is 'probably'. There are two designs- one which uses oil filled swivels where you have a drain and a fill plug on your swivel housing, and the later type which switched to grease. The common consensus seems to be the grease filled option is 'better', being fit and forget and less worry about it leaking out. 2005 Td5 90 XS 1989 V8 110 CSW |
8th May 2020 10:38am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Thanks for the reply, I had read your posts on the subject.
I have watched the trailer fitter videos and they are very informative. I will have to watch than again a couple of times as things tend to take time to sink in!! I am trying to establish if a kit of parts is all good stuff or I should also get this kind of seal or that kind of gasket - or buy the swivel housing on its own and buy these bearings, those seals and the other gaskets etc. I also wonder about the stub axles and bearings. If I am going to this much effort I don't want to have to revisit it to change the bearings in 18 months. I am going to have to change one of the front callipers so it may also be new callipers, discs and pads also - but then do you get the new brake pipes and braided hoses??? It could end up being a costly job and I have only had the truck a couple of months and not been able to drive it yet!! Thanks for the help. Regards Mick |
8th May 2020 5:47pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Although I wouldn't normally recommend Britpart spares, their swivel rebuild kits are good. If you choose the version that has a G on the end of the part number, it is all OEM parts inside such as Corteco seals and Timken bearings. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
9th May 2020 8:23am |
Thanks for the reply.
The "G" kits are quite expensive compared to the others and I don't have the money to buy genuine if the other gear is a suitable replacement, especially if weak component of a kit is inexpensive to purchase at the same time. I just have to watch the pennies! Spending money on OEM parts when it is not warranted means I can't buy other parts (and I have a few to get!!!). Saying that, I want to keep this truck so don't want to buy gear that is likely to fail. It is a balance getting the right stuff at the right price, but I hope with the help of you guys I can make the best choice. Many thanks for the help. Mick |
9th May 2020 11:07am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
OEM (or better) parts are always warranted.
The Britpart ‘OEM’ G-suffix swivels actually appear to be reasonable. I fitted a set to mine years ago before I knew the reality of their shocking quality control and other than the Teflon wearing off they have been okay. These days though I would buy genuine as I can’t bring myself to give Britpart any money. For the swivel job buy genuine or decent OEM branded parts - Timken bearings and Corteco seals as above. The Allmakes PR2 range is generally good. Costs more but it will last - mine have done over 230k since rebuild and are only now needing looking at again. Don’t fall for the myth that OEM means it’s the same as the genuine part in a plain box - while this may be true in some cases for many parts it is not. Each part must be assessed on its own merit. Good luck - a swivel hub rebuild is a messy job but fairly simple and a good way to get to know the business end of the vehicle. |
9th May 2020 10:29pm |
