![]() | Home > Tdi > Front and rear anti roll bars |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
I don't have anti roll bars on my 90 but my new (300TDi) chassis has them fitted, I assume these are the front ones you are referring to (just behind & below the engine mountings)?
![]() Click image to enlarge ![]() Click image to enlarge ONE LIFE, GET IT! |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 296 ![]() ![]() |
Yes they are the ones, think I might order the weld on brackets, liking the gav chassis cheers. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 648 ![]() ![]() ![]() |
The brackets were standard fit from 94 onwards so yours have been cut off for some reason, or the chassis has been changed.
The weld on brackets are fine, I’ve fitted a few of them years ago when upgrading pre 300tdi chassis 90s to antiroll bars,well worth doing. |
Thanks for that, presume they have been removed for whatever reason. Will get a weld on set ordered. 1999 300TDI 110 CSW BMW 3.0
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
If you need antiroll bars, rather than pay through the nose for a set of defender ones, it is worth noting the tdi Discovery ones fit just fine (and are usually thrown in the scrap). You will need the 4 bolt U clamp for the rear from a defender though as the disco only used a 2 bolt clamp. The fronts are the same.
Cheers for the info, will get looking. 1999 300TDI 110 CSW BMW 3.0
if you are on FB?
https://www.facebook.com/groups/9072945093...p_activity |
![]() 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5274 ![]() ![]() |
Laugh was, when i did this to my TDI, I only had the brackets for the front, Me and my mate later fitted the rear. We had to weld the rear brackets on the back. So looks like they must have added the full works on the later 300s, Mine was a 97 plater.
Funny thing was, it was the very last upgrade i did and never even got the use of ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
