![]() | Home > Technical > Dipped headlights intermittently going off |
Almost certainly melted terminals in the high beam stalk. Darren
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8182 ![]() ![]() ![]() |
Will have a look today, cheers Cheers
Sorted, you were right it was on the stalk. Dry joint on back of main light feed in to stalk.
Top tip, font take the stalk off the metal bracket without knowing what goes where for it to go back together! Took a while to work it out. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Broonster Member Since: 14 Dec 2019 Location: West Lothian Posts: 23 ![]() ![]() ![]() |
Umm, could I ask a stupid question please?? When you say ‘dry’, what do you actually mean? And how did you sort it?
I have this happening to my 90 and I’ve never touched car electrics in my life ![]() |
The live feed cable for the lights comes in on a cable to a pin on the back of the stalk. The pin is attached to a metal plate. Operation of the stalk sends the live feed from pin and hence plate to one of two outputs. In my case the pin was conducting to the plate. I put a lump of solder between the two. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17626 ![]() ![]() ![]() |
A "dry joint" is the term applied to a solder joint which has been poorly made and the solder hasn't "run", ie melted and flowed, between the parts to be connected.
