Home > Puma (Tdci) > Engine surging 1200-2000 rpm under load eg climbing a hill
Quattrocow
United Kingdom 1999 Defender 90 Puma 2.4 HT Baltic Blue
I can’t retire because I have one daughter getting divorced one daughter getting married and a Defender.
The Defender a 2.4 Puma (2009) @ 40k miles is surging under load at low speed and revs
The cam sensor has been changed with no effect.
God this thing eats money !!!
Post #828841 2nd May 2020 7:58am
InitIal thought, VCV.
Post #828844 2nd May 2020 8:29am
ickle
Fuel filter / fuel starvation?
Keith
Post #828845 2nd May 2020 8:31am
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 2008 is doing something that sounds very similar, worse when cold, albeit at just over 90k. I've recently changed the fuel filter so was thinking VCV. It's not enough of an inconvenience to be bothered yet.
They do eat money, but mine is now 12 years old; it's back from the dead (praise be, Dave Ashcroft) having been written off by a lunatic driver while parked, and it's the first time I've ever kept a vehicle for more than 5 years. My wife has had 3 vehicles in the same period, two of which cost more than the Landy did. Seems a pretty reasonable cost when you look at it that way.
Post #828874 2nd May 2020 12:38pm
Quattrocow
Sorry I am a bit of a green horn define VCV please.
I will have a look at the garage invoices to try and identify when the fuel filter was last changed.
All your help much appreciated
Richard
Post #828886 2nd May 2020 1:24pm
swt
It's the fuel vapour control valve, located on the back of the pump. If you search the forum for VCV, you'll find several good threads, including the symptoms that have been observed with a faulty VCV: we shouldn't rush to the conclusion that that's the fault, but it does sound like a possibility.
Post #828890 2nd May 2020 2:00pm
Strictly it's the volume control valve (commonly misnamed, even by Ford and LR as vapour control valve) and it regulates the flow of fuel from the low pressure stage of the fuel pump to the high pressure stage, and by so doing regulates the pressure in the common rail. It is constantly modulated by the ECM to adjust the common rail pressure appropriate to the engine demand.
Unfortunately it is rather fragile and very easily damaged by poor fuel, and especially by water in the fuel and/or the presence of the "diesel bug". It also lacks robust monitoring by the ECM and consequently it can malfunction quite significantly before any DTCs are logged. Generally with the 2.4 TDCi motor, a misfire or irregular running with no DTCs is a strong indicator of a faulty VCV since most other faults will cause DTCs to be logged.
It's a small valve located on the rear of the pump and is awkward to change due to access restrictions.
Post #828898 2nd May 2020 3:05pm
VCV details here if helpful:
https://www.defender2.net/forum/topic71207.html?highlight=vcv
There is a pic of mine showing it's location, torque specs and a supplier I used.
Failed Clutch switch is possible too of course. Chillin In The Backwoods🇬🇧🇺🇸
Post #828919 2nd May 2020 4:55pm
dgardel
Italy
Re: Engine surging 1200-2000 rpm under load eg climbing a hi
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #829212 4th May 2020 1:27pm
