Home > Puma (Tdci) > Interior lights only work manually not in 'auto' |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
It will probably be your door switches have either broken or corroded through . Open your door and give the little button a wriggle , it may need pulling out if it’s been distorted . If the lights come on , then that’s your problem, relatively easy fix ! https://www.instagram.com/hustynminepark/
29th Apr 2020 8:13am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
The alarm ECU receives the door switch inputs and switches a 12V ground feed to the interior light(s) when a door is opened.
There are two door switch inputs to the ECU: one for the driver's door and one for all the other doors in parallel Unlikely all the door switches are faulty but you never know Check Fuses 6 and 7 which are the supply to the alarm ECU. Edit: stupid boy 1988 90 Td5 NAS soft top 2015 D90 XS SW Last edited by Martin on 29th Apr 2020 10:59am. Edited 1 time in total |
29th Apr 2020 9:02am |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 |
as above check the fuses and the door switches first. I had the exact same symptoms as you have mentioned, changed the fuses and checked the door pins and both were fine however the light would still not function in the auto setting, I took the off chance that it was the light that was faulty and purchased an Mud LED one and that fixed the problem so in my case the unit itself was broken. Just something worth considering after you have tried the usual culprits.
29th Apr 2020 9:16am |
door switch inputs are "to ground" when doors open Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
29th Apr 2020 9:31am |
rizga1 Member Since: 14 Apr 2020 Location: QZ Posts: 28 |
Thanks everyone.
The door switches seem to wiggle fine and look to be in perfect condition. I have not checked those fuses yet but I will do so. The alarm should be OK though because the little red LED in the dash flashes as per the owners manual. I would not think both light units would be faulty. Thanks again. |
29th Apr 2020 9:39am |
The alarm ECU transistor output for interior light auto the output grounds pin 1 Gray connector
29th Apr 2020 10:30am |
Corrected my post above 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Apr 2020 10:59am |
Something else has just occured to me, aren't the indicators supposed to flash 3 times when you lock the car?
Mine don't so maybe the alarm has got an issue. Anyway I will check fuses 6 and 7 as soon as I get a chance. |
29th Apr 2020 11:15am |
key fob battery low |
29th Apr 2020 11:23am |
Oh right, will change them out. Thanks.
29th Apr 2020 11:34am |
