Home > Td5 > Cat D
paddy9154
Cat D
Hi all,
First post so please be gentle.
I'm currently toying with the idea of a Td5 as a second car / weekend toy.
I've found what was initially a good offer but turns out to be a Cat D due to front end collision damage. Never even considered this before but I guess it's not ideal, hence the price.
So given the value of an unmolested example is Cat D the sign of some hefty repair?
Thanks in advance
Pad
Post #82811 1st Aug 2011 11:19am
It's not always a bad deal, if you can live with it being a Cat D..and as long as you check it over VERY thoroughly, they can be a bargain !
Make sure it has an engineers report too.
Post #82819 1st Aug 2011 11:59am
Lorryman100
Hi and welcome to the forum Thumbs Up IIRC these are the Cat explanations:
Cat A - Fire damaged (burnt-out), flood damaged, or severely damaged with no servicable parts.
Cat B - Damaged beyond economical repair and/or severe structural damage.
Cat C - Damaged, but repairable. Generally applied to older vehicles.
Cat D - Slightly damaged sometimes stolen and found after claim has been paid or high cost of repair combined with difficulty obtaining new parts to enable an economic repair. Basically the car isn't worth repairing as it would cost more to repair than what the vehicle is worth.
I'm sure someone in the trade will come along and aid you further.
Post #82820 1st Aug 2011 12:02pm
T1G UP
my first td5 was a cat d, farmers 90 tc that had a damaged ( slightly bent) rear cross member due to a wayward trailer and a damaged rear tub. 50k and fsh from matfords. paid £4000+vat and at the time that was 50% of its true value.
front damage is a little more iffy it the chassis took a good whack, BUT with a LR you can have a new , galvy chassis fitted for £2500 so again no real problem
Post #82841 1st Aug 2011 3:19pm
landy andy
If you like/want it take it to a specialist, get it on a ramp, and get it checked through, for you. NOT for the seller.
If all ok pay a lot less than book value
Andy
Post #82855 1st Aug 2011 7:04pm
paddy9154
Thanks for the help with this.
Still a lot of thinking to do, I know it doesnt matter if its been repaired properly but its still a bit of a psychological hurdle!
Post #82893 2nd Aug 2011 9:31am
K9F
It needn't be! Especially if it's 'stolen recovered 'and the damage you describe is a result of that!' Ask what the history is and who did the repairs! Then contact the repairers and/or ask the seller to look at the invoice for the repairs. That will be a good indication how good or bad it is, if the information you requested is readily fothcoming it may be worth a sniff! If they don't have them or make feeble excuses WALK AWAY with a clear conscience!!!!
As Landy Andy so rightly said "Get it on a ramp!" An AA or RAC inspection may be worth shelling out for, or, if you have a decent independant nearby gauge the sellers reaction by asking if he minds an independant mechanical/valuation/inspection of the vehicle at your cost being carried out.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #82898 2nd Aug 2011 10:44am
