Home > Technical > Converting Puma to R/H drive. |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
Has anyone done this conversion to a Puma or know of a company that can shed some light on the subject.I'm moving back to South Africa and the Landy has to be R handed.I don't have ABS/TC to contend with which is a good thing and the work can be done here localy or can take a trip to the UK.
I have had a look at the most parts required,but confused with the aircon.The unit for R/H drive is listed as different and can't fathom out why except for the air ducts on the top half of the dash. Thanks chaps Puma 110 SW 90 V8 SOFT TOP |
1st Aug 2011 7:27am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Try Staffordshire4x4
1st Aug 2011 10:32am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Thanks Chris.
Pm sent !!! |
1st Aug 2011 10:54am |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Sorry,
But will not be cheaper sell the L/H one and buy an used R/H in UK and move it to South Africa or buy one there? Just a thougth... Anyway is good to have all options open. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
1st Aug 2011 1:02pm |
I have a trouble free one that I do not want to let go and a I have to own the vehicle in my country of residence for a year to be able to import into SA. Puma 110 SW 90 V8 SOFT TOP |
1st Aug 2011 1:28pm |
Thanks.Have sent you pm. Puma 110 SW 90 V8 SOFT TOP |
1st Aug 2011 1:44pm |
OK. Problem understood Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
1st Aug 2011 3:31pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i'll buy the LHD bulkhead, and associated parts
1st Aug 2011 3:41pm |
I'll keep you in mind.Thanks Puma 110 SW 90 V8 SOFT TOP |
2nd Aug 2011 12:37pm |
With some carefull drilling,no bulkhead swap is needed.I'm smilling. Puma 110 SW
90 V8 SOFT TOP |
5th Aug 2011 10:45am |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
και μεις που καθομαστε τι κανουμε............... www.newfoundland.gr
10th Aug 2011 9:23am |
Things will improve,but it will take a long time.I'm going back and starting from zero,so it should give you an idea of how fed-up I'm of Greece.I still do wish the country well and my investments will stay intact. Puma 110 SW 90 V8 SOFT TOP |
10th Aug 2011 10:29am |
my best wishes man!
be careful boerboels www.newfoundland.gr |
10th Aug 2011 1:51pm |
