Home > Technical > Swivel housing resistance setting |
Click image to enlarge |
27th Apr 2020 12:49pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 |
Hi hufflepuff, your picture doesn't show it, but have you left the swivel seal unattached?
The resistance figures you've given are for the pull without the seal in place. Apologies if that's too obvious, but the same question was posed just a few weeks ago, and that time, the seal had been fitted. I think there's more initial resistance, but then the quoted figures are for the 'steady pull / swivel moving' phase - even it if is quite a short range of movement. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
27th Apr 2020 1:02pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 793 |
Got to do this job in a few weeks.
not particularly looking forward to it. Chris |
27th Apr 2020 1:17pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
Thanks for the feedback gentlemen.
The seal is not fitted at the moment, as per trailer fitter Chris’ recommendation, the ball is just mounted to the axle with three bolts. The workshop manual for the 300tdi is stating only 1.5kg if force then Dorsetsmith? I wonder why the Haynes manual is so different. I actually bought Brooklands dork shop manuals for both the older models and the td5 onwards, but I have not been able to locate the procedure for the swivels in them. I will go and have another look... 2005 Td5 90 XS 1989 V8 110 CSW |
27th Apr 2020 1:18pm |
Heh just realised the workshop manual states 78nm for the top pin bolts, Haynes says 65nm. 2005 Td5 90 XS
1989 V8 110 CSW |
27th Apr 2020 1:20pm |
well, fwiw, I had the 300Tdi workshop manual right beside me... that says 1.16 to 1.46kg once the initial inertia has been overcome. Donald
Good spot!
I keep an old copy of the Haynes manual under one of the second row seats for 'emergencies'. But it is worrying if they can be so far out. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
27th Apr 2020 1:22pm |
Ah the mystery deepens. In the workshop manual 1983-1995 MY, it states 3.6 to 4.5kg, the same as the Haynes manual. I wonder if Land Rover updated the procedure when they moved away from the Railko bush. 2005 Td5 90 XS
1989 V8 110 CSW |
27th Apr 2020 1:26pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
You are correct, the lower drag force should correspond to the use of the upper and lower taper roller bearings. The higher setting was for the Raiko bushing.
Be aware that one of the workshop manual gives a ridiculous torque setting for the lower swivel pin retaining bolts (which are only M. EDIT: It is infact step 45 in DorsetSmith's screenshot of the manual that specifies 78Nm for some M8 Gr8,8 bolts Steve 02' 110 TD5 Double Cab Rebuild Thread Last edited by rallysteve on 27th Apr 2020 1:48pm. Edited 2 times in total |
27th Apr 2020 1:43pm |
OK moving forward. I have located the page in the newer workshop manual which Dorsetsmith referenced. Section 54, which *Obviously* comes right after section 88.... how obvious.
I wonder if the ball joint bore it is stating to hand the spring balance off is the front, longer arm? The earlier manual was stating the rear shorter tie rod arm. It is possible that 3kg on the short one is the same as 1.5kg on the longer arm, I will go and measure. Annoyingly the newer doc is stating the lower pin bolts should be 78nm. The older workshop manual states 22 to 28nm, which did not seem much at all. Pity I have lot items those in already, I will remove, clean and redo to the higher torque, and then just follow the newer manual’s instructions throughout. 2005 Td5 90 XS 1989 V8 110 CSW |
Oh heh our posts crossed there Steve on the torque settings. 22-28 seems pretty low though. 2005 Td5 90 XS
1989 V8 110 CSW |
27th Apr 2020 1:44pm |
ah yes!
The bolts are only M8- Gr8.8 so that torque is correct. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
27th Apr 2020 1:47pm |
Sorry which is correct, the Lower 22-28nm? 2005 Td5 90 XS
1989 V8 110 CSW |
27th Apr 2020 1:50pm |
Yes sorry, the 22-28Nm is the correct tightening torque for a Gr8.8 fastener. Much more than that and it will be at risk of shearing off.
Cheers 02' 110 TD5 Double Cab Rebuild Thread |
27th Apr 2020 2:21pm |
