Home > Maintenance & Modifications > TD5 clutch alignment tool |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
22mm pipe
26th Apr 2020 5:13am |
If you bu lof clutch you get a nice green alignment tool
26th Apr 2020 5:15am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Do you ? I didn’t
26th Apr 2020 6:37am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17491 |
I use a Sykes Pickavant clutch alignment tool that I've used on every clutch replacement I've done (which is many) for the last 45 years or so.
26th Apr 2020 6:42am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Prior to getting a clutch alignment tool, I'd always used a deep socket or a 1/2 inch extension bar with a few layers of electrical tape wrapped round to thicken it up, never had any problems. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
26th Apr 2020 8:28am |
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 |
Thanks - that sounds by far the cheapest option |
26th Apr 2020 2:56pm |
Clutch end
Click image to enlarge Click image to enlarge bush crank shaft end Click image to enlarge |
26th Apr 2020 3:36pm |
I still fail to see why alignment tools for the TDV6 engine are so common and not so for the TD5.
26th Apr 2020 4:22pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
All I ever do Click image to enlarge Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
27th Apr 2020 8:08am |
