Home > Technical > Rear door 'finishings' - part numbers...? |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
Hi guys,
Looking to finish fitting the rear door. A couple of things have me kind of stumped. Because I'm not using original stuff, the age of the car is irrelevant in this instance. First is the escutcheon or seal around the rear door lock. This thing here: I've got a whole new set of locks - the ones which take the larger barrels - post 2002 I think. The new lock has an external diameter of 23mm; the original is 19mm. The part number I was pointed towards was EKC000030PMA - but I think that's the smaller one; I can't find any size references for CWN100020L but I'm leaning towards buying this just on the basis that it's a different number than the one above. Has anyone got one of these recently and is able to confirm if it's for the larger diameter lock? Neither are particularly expensive, so I guess I could order both and use the one that works, but better to get just what I need if I can. Second - is the internal handle. The original is just about knackered. If any weight gets put on it, it's only a matter of time before it snaps. I think RRC5662 is supposed to be a part number for a 'strengthened' military version, but the pics showing up on google make it look more or less identical to the 'civilian' or standard one. If there's a usefully stronger version, I'd get that, but if it's just about the same, I think I'll find some sort of other alternative - from a chandler or playground fittings or something like that. Anyone got hold of the military one that can comment if it's worth using? Thanks as always. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
20th Apr 2020 8:05pm |
Looking at pictures of the military handle, it's exactly the same as a civilian one. Darren
20th Apr 2020 8:26pm |
Yep, that's pretty much what I thought, but I did just wonder whether "the internet" was confusing the two, and that someone with experience of both might say there was some sort of strength benefit. Donald
20th Apr 2020 8:32pm |
Thanks for that. I didn't know there could be any issue with the striker, so just changed the lock, and bashed on. Happily - by luck if not design - there seems to be no problem. The door closes and latches properly, and locks fine. I'm assuming the striker is 1994 standard, so maybe it's worn perfectly!
I maybe confused things talking about military versions of the internal handle. The lock mech is not military, and just a new lock so that I could have all doors, and ignition on the one key. (Though having achieved that, I am going to fit deadlocks!) Good to confirm that EKC... is the smaller one, which does point to CWN... being correct. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
20th Apr 2020 9:36pm |
