![]() | Home > Maintenance & Modifications > canm8.com Precision Cruise Control |
izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26 ![]() ![]() ![]() |
Has anyone installed one of these Kits? Any reviews on its operation and installation?
Looks like it would be a fairly straight forward install. http://www.canm8.com/precision-cruise-land-rover-defender.html ![]() Click image to enlarge |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 ![]() ![]() ![]() |
I asked the same question here - half way down the thread. result was that no one had tried at that stage but that may have changed by now.
https://www.defender2.net/forum/topic67464.html thanks Mike |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
I looked at this a while back but it looked as if the stalk is only left hand side fitting, and as there are already two stalks on the left, I thought it would be awkward to fit and use.
Love to see a pick of if someone has fitted one and where. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3797 ![]() ![]() |
On the book of faces, someone on their has just fitted one
They reckon on it taking 4 to 5 hours and it very happy with it.... Details from the post below.. UPDATE I recently purchased a Precision Cruise Control unit from Canm8.com. Firstly, excellent customer service and replied quickly to my queries. The unit is a considerable amount cheaper than other brands out there. Furthermore, it has the additional feature of a Limiter which some others do not. I installed the unit today, relatively easy if you know your wiring and are good with a soldering iron. First test drive had me pleasantly surprised! It’s a good looking unit, easy to use and is very responsive! I would thoroughly recommend this unit to anyone looking at installing a cruise control unit. I will upload some pictures of the install in due course. http://www.canm8.com/precision-cruise-land-rover-defender.html ![]() Click image to enlarge ![]() Click image to enlarge |
Is it for a td5?
If so the ECU is ready for it you only need a few wires and 2 push buttons. If so I have the schematic somewhere. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
4-5 hours for £185!?
As said above you can do it with a bit of wire and a couple of carling switch, or genuine dash switches to fit some blanks on the centre cluster. I guess including switches that would cost less than £20... Insta: @thebenjordan4x4 |
You can on a td5 yes... this is for puma.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Those cruise control sticks aren’t great quality, and a very fiddly to use on the move. I’ve fitted one to a different vehicle and it is far from “natural” to use.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
Looks good
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
notxal Member Since: 20 Nov 2019 Location: Shropshire Posts: 89 ![]() ![]() ![]() |
We’ll I’ve just fitted the CanM8 Precision Cruise control. Took about 3.5 hours to complete the installation. Most of the time was spent routing the wires and gaining access to the various wire tappings. At one point I had to ring CanM8 as their instruction Regarding the Clutch switch connection was out of date as there is no longer a need to Earth the system.
In terms of functionality it’s really good especially the speed limiter (as if Defenders needed this function!) which many aftermarket Kits do not have. A good system at a very good price compared to other kits. ![]() Click image to enlarge Last edited by notxal on 24th Jul 2020 1:01pm. Edited 2 times in total |
Jamesgs Member Since: 14 Apr 2015 Location: Altrincham Posts: 4 ![]() ![]() ![]() |
Good to hear as I bought one earlier in the week - to be fitted soon !
I fitted mine yesterday - fairly straightforward. Works really well - a bargain in my book......
blackrock Member Since: 01 May 2022 Location: Hampshire Posts: 57 ![]() ![]() ![]() |
I fitted one of these 12 months ago and it was fine, until about two months ago when I started to get
P2122 OBD errors and Limp home mode. It was infrequent to start with and got progressively worse. That error is to do with the redundant throttle pedal potentiometer signal not matching correctly with the other signal, I believe. Once it got unbearably frequent I sapped the cruise unit out and all is fine now, so it does look like the cruise control system. I've contacted CANM* twie now by email and had no reply at all, and the unit is now out of their 12 month warranty. Not too happy about hearing nothing back. I've checked the wiring and can see no problem, and looking at photos of someone installing the same unit, I have done exactly what they did. The photos could have been of my installation. I initially thought that the cruise unit was a CAN bus interposer type thing but it looks like it is actually an interposer between the pedal potentiometers and the ECU, so it is actually a lot simpler than I thought. Also, it looks to be a generic unit from somewhere that a lot of people sell. I've not tracked down who exactly sells it. So, as I miss cruise after having had it, I have bought another kit (I know), so I can put what i hope is a known good unit in and see if it is the unit or the wiring. I suppose I'll have a spare if that unit shows up a wiring problem. As the pedal potentiometer wiring is all pre-wired in the kit I can't really see why my wiring would be at fault. Has anyone else had this sort of problem? I'm also contemplating building a test jig to see if I can fault find the original unit if it does seem to be a problem, anyone done that? As a wild idea I was also wondering about building my own cruise unit, at least I could fix that if it went wrong. Andrew |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
Ive fitted this cruise control to both our 2.2 puma 110’s and have has no issues (...so far!)
We did a 4230 mile trip to mid Sweden last month and the cruise control was faultless. The position of the stalk is fine as its easy see and action - the lights on the stalk are easily visible when in use. There is some ‘wiggle factor’ when fitting the stalk for optimal position which helps in the set up. The limiter was put to the test with the many 20mph zones in towns and villages on the way. Fitting was reasonably straight forward apart from when I dislodged the break pedal sensors and took a little time to diagnose the issue - once diagnosed it took 2 seconds to fix and job done. I drive from Cornwall to Aberdeen every month and the cruise control has been wonderful over the last few months, and has been helping with keeping my MPG lower than before fitting, really enhanced my driving experience so it gets full marks from me! (n.b. - I have not had the pleasure of fitting or testing other designs so am not able to comment on other units and their use) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
