Home > Puma (Tdci) > lights blowing fuse....
leonski
Dear All,
Has anyone any idea what could be causing this......
I upgraded the headlight bulbs a while ago with some from Halfraud's. They have been fine for months but I have just noticed that my full beam on the drivers side is out and blowing the fuse (immediately).
Today I replaced them with some new Philips bulbs, everything worked fine when I tested them...until I put the side lights and indicators back in!....fuses still blowing......
Has anyone any idea? I would really appreciate any advice.
Cheers,
Leon.
Post #82598 29th Jul 2011 8:53pm
markb110
Hi
I had something similiar in the past,
Check the rear number plate light bulbs as they may have moved - the fitting is pants and hence the bulb moves and pops the fuse.
To fix this i used a couple of zip ties to secure the bulbs to the mount.
Good luck
Mark
Post #82600 29th Jul 2011 9:02pm
nicknick
England 2010 Defender 90 Puma 2.4 CSW Tonga Green
Hi Leonski
for something to blow a fuse it means the live wire must be touching earth ie bodywork somewhere.
so it needs to be traced in a logical way, i would start by disconnecting the headlamp which is not working then replace the fuse and turn the headlights on leaving that one disconnected.
if the fuse blows again the wiring has rubbed somewhere, if it doesnt blow then you have a faulty bulb.
its a start and i hope you find your problem Thumbs Up
Post #82601 29th Jul 2011 9:07pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
is it not under warranty ?
Post #82602 29th Jul 2011 9:14pm
leonski
Thanks for your replies guys...
I will investigate further today.
It is under warranty, but it is a 65 miles round trip and probably half a day or so of hanging around....I was hoping that there may be a simple solution!
Leon.
Post #82615 30th Jul 2011 5:31am
Happyoldgit
What sort of upgraded bulbs and how much additional load are they putting on what after all is marginal wiring and switchgear anyway?
If it was ok before you replaced the bulbs it's either that you've disturbed something, or there was a pre existing fault. Check the wiring and associated components and it may be worth trying standard bulbs again. Steve.
http://forums.lr4x4.com
Post #82619 30th Jul 2011 7:55am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
One of my headlamps kept blowing the fuse, turn out to be wiring had rubbed on the wing edge under the bonnet in the back left hand corner of the engine bay next to the ABS pump.
I did post about it on the foram somewhere before to warn others in case it happened to them.
Post #82622 30th Jul 2011 8:19am
Grockle
could be pulling to much current through now,I had this on an Audi some years ago I had to up the fuse by 5 amps to stop it blowing 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #82625 30th Jul 2011 8:29am
K9F
Good joke!! If it's pulling too much current either the wrong fuse was fitted or you have a fault!!! Laughing
Generally 'good working practice' is that the fuse rating should't be more than 1.5 times the working current of the circuit it's providing or round up to the next amp if it is a designated circuit that will have a single application! It can be worked out using the following formulas:
Power (Watts) = Voltage X Current
Voltage = Current X Resistance
For certain circuits (for example electric motors) HT or what is known as 'anti rupture' fuses should be used as the instantanious starting current exceeds the normal operating current of the circuit. These fuses have the filament supported in a medium such as sand or porcelain to dissipate heat and prevent the fuse from rupturing on initial start up.
Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #82632 30th Jul 2011 9:27am
Grockle
I see your plugged in to day Mal Thumbs Up 2.4 90 XS
Post #82633 30th Jul 2011 9:32am
K9F
'Plugged in' and charging at a rate of 1 amp per hour protected by a suitably rated anti surge fuse! Rolling with laughter
Off Topic Feel like a flippin' vampire working constant nights from now til October. Fancy popping out for a bite?
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #82635 30th Jul 2011 9:39am
leonski
Thanks for all your advice!
Found the problem!
The wire had rubbed through on the inner wing!
The cable really should have some trunking on it, and as Daz said, I would advise everyone to check theirs.
Its a pretty shoddy lack of attention to detail by LR!
Sorted!
Cheers,
Leon
Post #82648 30th Jul 2011 11:44am
