Home > Puma (Tdci) > Do I need to remove the brake lines to remove clutch pedal?
Co1
Fitting LOF master cylinder and no way to do it without moving the pedal box all together, but will I also need to remove the brake lines that run over the top or am I missing a trick?
Post #826167 18th Apr 2020 10:24am
Balvaig
Never had to do it but according to the Workshop manual, yes you have to remove the brake lines.
Post #826201 18th Apr 2020 1:08pm
Co1
Thanks Balvaig. Is that manual available online?
Post #826265 18th Apr 2020 6:08pm
Balvaig
Yes.
Try the following:
http://sdrv.ms/199QUa1
Not good on technology so if it doesn’t work, just do a search on this site.
Post #826289 18th Apr 2020 8:40pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
NO you don't have to remove brake lines.
It would possibly make it easier but I have done heaps without removing them just remove the separator plate they will flex out of the way.
Mark
Post #826302 18th Apr 2020 10:27pm
Co1
Balvaig wrote:
Yes.
Try the following:
Thanks. Much appreciated.
Post #826316 19th Apr 2020 7:05am
