Home > Maintenance & Modifications > New locking wheel nut cover won't stay on |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
The locking nut covers are dimpled, in order to indicate that they are the removable ones. It is quite common for them to be loose (they're a pretty naff design, really), I usually squeeze them in a vice to make them a little tighter, and also when fitting give them a 30 degree twist with the wrench so that the spikey lug on the locking nut digs into the flat face of the cover.
It is also possible to squeeze the "rim" at the open end to make them tighter, but this can make them difficult to get on. |
16th Apr 2020 9:38am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2166 |
Drop of silicone or RTV. Instagram @defender_ventures
Empire Tuning - Agent |
16th Apr 2020 10:20am |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 |
Update: I used some RTV 3140 or 3145, and it seems to be doing the job.
I did have to take the wheel off to do some brake bleeding, and so I had to take some of the RTV off to get the locking wheel bolt key over the teeth, but it still seems to be holding on. Only time will tell... Cheers! |
26th May 2020 9:21am |
