Home > Maintenance & Modifications > Puma Steering Issue |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello D2N I'd appreciate your thoughts on a steering issue 'that has developed' for me
Vehicle 2010 2.4 tdci / 48K mileage Non Standard 'set up' 20 Inch Landrover LRX Wheels / 275/60R20 Cooper Zeon Tyres 30mm Offset Spacers, Top and Bottom Spring Isolation Rubber Dampers (each 10mm thick) all four corners Click image to enlarge Click image to enlarge Click image to enlarge The Issue... I've now covered 42K in this Defender, it came with the 20 inch wheels, which I initially intended to swap out but the vehicle drove well and I guess I just got use to it, I have subsequently added top and bottom spring isolation dampers (OEM LR) so technically this will have raised the vehicle <20mm (now compressed when fitted) After fitting these there was NO perceived difference in handling... but a marginally quieter cabin noise. I have what can best be described as a progressively (increasingly) 'nervous' vehicle. up to 50 mph all OK, 50-60 mph bit of steering 'lightening / wobbling', 60+ then better. At any speed it now feels that it is 'hunting around' a bit, and I'm correcting something... but what is the cause or possible causes (it's a Land rover) All wheels have been off and balanced checked....all OK Maybe I have found the problem... I recently serviced the vehicle and when checking the front axle oil... it was 'over filled' how could this be as you fill to the filler plug and then seal up. On reading up I see the seal / gasket thing between the swivel pin housing and the axle often breaks down and the one shot grease designed to stay in the swivel housing doesn't.... I first drained off what I thought was a problem, drove the vehicle (worse) replaced (added) two more one shot grease sachets, one each side, and she was much better but not 100% So what's next... 1. Do I strip down and replace seals 2. Do I just add more one shot grease 3. Do I look to making my particular set up better (maybe after the above) by adding in a more powerful 'Return to Centre Steering Damper / Stabiliser (Terrafirma / Old Man Emu) 4. Possibly would a set of Caster Correction Bushes (ideally not Arms but maybe) be a consideration on a Defender with 20 inch off set wheels with about a <20mm additional lift from standard. 5. How do I check that steering 'box' is as it should be with 'wear' within tolerance With thanks... SKIP https://www.defender2.net/forum/topic83242.html |
15th Apr 2020 9:22am |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Big wheels can often cause the steering g bars to vibrate at higher speed this causing wobble/vibration id have a chat with the guys at Gwyn lewis and get a set of sumo bars and also worth doing the disco drop arm conversion
I’ve done this on mine running 18’s and it’s made a world of difference 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
15th Apr 2020 9:33am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5665 |
If you can, which I can understand will be difficult at the moment, try a standard ish set of wheels and road test it.
15th Apr 2020 2:20pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
I would check the "usual suspects" first, especially the suspension and steering bushes, and all steering ball joints.
Sumo bars work well on my USW making it feel much more planted but there is something amiss with your set up that has occurred over time, indicating component wear. Just because you're offended doesn't mean you're right. Last edited by shropshiredefender on 15th Apr 2020 2:45pm. Edited 1 time in total |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2225 |
Have you got any play in the swivel bearings?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
15th Apr 2020 2:24pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 729 |
Could also be wear on the tyres themselves. They will balance; but wear, particularly if uneven, can cause wobble.
15th Apr 2020 2:51pm |
