Home > Td5 > injection harness original equipment or land rover
alexatnd
quick question
Land Rover part or Original Equipment for an injection harness ? Sort of biased towards the LR one but thought I'd just ask given LR = 2 * OE
best
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #825211 14th Apr 2020 12:58pm
excossack
Just ordered a new LR one via Duckworths. Original for me. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #825220 14th Apr 2020 1:25pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I use OE and save the money. I also change it every two or three years and consider it a service item. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #825229 14th Apr 2020 2:19pm
bankz5152
LR.
Id always keep a spare one. Second theres a drop of oil in the red plug swap it again. Changed mine 3 years ago now and not a drop in the plug. Change the rocker gasket at the same time Elring do decent ones. Instagram @defender_ventures
Empire Tuning - Agent
Post #825276 14th Apr 2020 5:33pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Changed mine 2 yrs ago with genuine LR one Thumbs Up
Post #825310 14th Apr 2020 7:02pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Repaired my original more than 8 years ago, and no problems. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #825340 14th Apr 2020 8:10pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Everyone repeatedly changing theirs: I thought once you put in an updated loom then it fixed the problem and you didn't need to worry about it again? Insta: @thebenjordan4x4
Post #825435 15th Apr 2020 7:08am
bankz5152
Oil can still make its way down the loom. Instagram @defender_ventures
Post #825436 15th Apr 2020 7:13am
excossack
Mine did Sad LR one lasted me around 7 years. 1999 Defender TD5 110
Regards
John M0VAZ
Post #825441 15th Apr 2020 7:20am
roel
Put an OE in in 2009 still no oil in the plugs.
However I filled the top side off the connector and I only drove 40.000 M since.
And maybe my ECU is placed on the bulkhead between the seats That could help too. Roel
2003 90 Td5 (2009-now)
Post #825461 15th Apr 2020 8:25am
excossack
Roel
Did you add sealant to cover the 4 holes in the top of the plug that joins to the main loom?
AMR6103 is the part number 1999 Defender TD5 110
Regards
John M0VAZ
Post #825506 15th Apr 2020 10:12am
roel
Yes I took the cover off and squeezed it as much as possible full with silicon blue headgasket sealant. Straight when it was new. Cleaned the internals first with brake cleaner to get any existing grease out and give the sealant a fighting chanche to get a good sealant. Roel
Post #825524 15th Apr 2020 11:24am
excossack
Cheers. I will be doing the same then. 1999 Defender TD5 110
Regards
John M0VAZ
Post #825544 15th Apr 2020 12:48pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
How much? Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #825568 15th Apr 2020 2:45pm
