Home > Maintenance & Modifications > Refurbishing the rear cross member
CRT188
Hi guys
I wanted to refurb the rear cross member
Any suggestions on preparing it before using the FXLiner buzzweld product
Thanks Thumbs Up
Post #824962 13th Apr 2020 12:20pm
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hey CRT188- I have just done mine using the Buzzweld kit. Used a wire bush on a drill to clean it back to the metal and take all surface corrosion off. Products worked really well just make sure you mask off well.
 Keswick green 2007 Defender 90 TD5
Post #825004 13th Apr 2020 3:43pm
CRT188
Hi Marcus
Looks great!!
I’m crap at this kind of stuff, what type of brush did you use?
First time I’m actually trying to do anything on the truck myself Surprised, usually leave to the professionals Very Happy
Post #825031 13th Apr 2020 6:05pm
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
You'll be fine, I'm very new to all this and I did mine a couple of days ago. I just sanded mine by hand with some 80grit sand paper and then sprayed it with the buzzweld 2 part crossmember kit. As previously said, just double check you have masked everything you don't want spraying
Post #825049 13th Apr 2020 7:45pm
Sulisuli
Nice tidy work Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #825052 13th Apr 2020 7:53pm
MarcusM
CRT Just used the Buzzweld kit - comes with the rust encapsulator spray can and then the black spray. I’m pretty new to it to - was the first big job I did- pretty easy and gives a great result! Good luck with it and post some pics Keswick green 2007 Defender 90 TD5
Post #825055 13th Apr 2020 8:03pm
CRT188
Thanks guys, I’ll order it tomorrow, not sure if they are open.
Post #825063 13th Apr 2020 8:34pm
MarcusM
This is the one I used - they are still shipping out - I imagine they are doing well right now!
https://www.buzzweld.co.uk/fxliner-1k-cros...g-kit.html Keswick green 2007 Defender 90 TD5
Post #825066 13th Apr 2020 8:40pm
