Home > Puma (Tdci) > Led driving lights flashing when using battery optimiser
Landymatt
Had a weird one last night, the dogs started kicking off about 1am so I went to check out what the commotion was.
Led lights on the bumper were coming on for a few seconds, then off maybe 30 seconds.
Earlier in the evening I’d hooked my Optimate up to the battery with everything still connected up (because it said you can do that in the charger manual, hope that’s right).
Out of interest, the Optimate showed red (low) for the battery indicator as had been stood for couple of weeks. Thinking maybe it had reached a level where it started pulsing charging or something similar.
Interested to hear any thoughts.
Hope you’re all keeping OK,
Matt
Post #824861 12th Apr 2020 6:29pm
bear100
It’s the voltage sensing module on the DRL’s I have the same issue well mine stay on after around an hour of the ctek charger being plugged in. Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #824874 12th Apr 2020 8:08pm
seriesonenut
My DRL's were the same and as I have fitted a voltage sensitive relay to power the dash cam and some other kit all sorts were coming on and off when connected to the charger. I fitted an isolation switch in the end so when the charger is on the accessories are cut off. 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #824876 12th Apr 2020 8:13pm
