Home > Maintenance & Modifications > Can anyone identify these cables. |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
Gearbox temp sender, but only if there was one fitted.
11th Apr 2020 6:56pm |
C219 Connector - Defender 1996 300Tdi
Home > Connectors > Defender 1996 300Tdi These connectors are shown for educational purposes. If you find the information valuable then please consider purchasing the appropriate Electrical Connector Library LRL0126ENG. Switch - Oil temperature C219 is a natural, female connector with up to 1 wired pins. The connector's location is Beneath centre console LH side. This connector was used in 1996, 1997 and 1998 models of Defender. C219 Defender 1996 300Tdi location Add comment Pin Wire colour Vehicle type Wires to Mates to 1 Slat gray Red All C269 black oil temp switch |
11th Apr 2020 7:02pm |
Bathale Member Since: 02 Sep 2016 Location: South West Posts: 100 |
Thanks very much for the fast replies.
I will indeed look at getting the relevant publication. Thanks again. |
11th Apr 2020 7:18pm |
