Home > Maintenance & Modifications > Nakatanenga Aerial
ibexman
Nakatanenga Aerial
I’ve ask Brendan this question and he doesn’t know
Will the Naka Aerial work on AM/FM without power ?
Post #824365 10th Apr 2020 7:43am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I have the naka ariel and it great
Are you using std headunit?
Or double din? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #824366 10th Apr 2020 8:09am
pj2106
Reason I ask is mosjority if upgraded units have the option to power the antenna which won’t work with the naka anyway
But for am/fm I found out the long way that yes the am/fm does work with out power but dab does not if powered through headunit
Why dont you want to power it?
Hope this helps 2008 110 2.4 XS Utility (Hagrid)
Post #824367 10th Apr 2020 8:12am
ibexman
Hi Paul no just have a shallow single din it just for am/fm reception I’ve had dab too patchy for me cheers chris
Post #824372 10th Apr 2020 8:44am
pj2106
My dab was rubbish till I got the naka ariel been all over the uk and had no problems with Dan now 2008 110 2.4 XS Utility (Hagrid)
Post #824375 10th Apr 2020 8:54am
pj2106
DAB not dan
If you just want good and/fm a decent flexi Ariel would do you tbh the naka ones not cheap but defo worth it if you want dab 2008 110 2.4 XS Utility (Hagrid)
Post #824376 10th Apr 2020 8:55am
ibexman
Thanks Paul 👍
Post #824377 10th Apr 2020 9:03am
I’ve tested mine and it seems good, but still not in full use yet until I’ve done my install.
Don’t forget also if you have a HU that can power a DAB aerial to have that setting turned OFF with the Aerial externally wired in otherwise it won’t work.
On mine this come up on the opening screen after power has been disconnected.
From when I tried the aerial it picked up a good amount of DAB channels and that was parked in a relatively confined area amongst buildings too so I’d say that’s pretty good. $W33T $0U7H3RN $UG4R
Post #824391 10th Apr 2020 11:31am
I can't answer the original question (about FM/AM reception without power) although I would expect the aerial to work in this scenario, but I can say that I have been massively impressed with the performance of mine.
When I first fitted a DAB receiver I had a DAB aerial mag-mounted to a steel plate on the roof-rack (the steel plate providing a ground plane) and the reception was utterly useless. It would work fine very locally, but was completely inadequate for regualr use.
The Nak aerial provides stunning reception even in areas where I wouldn't expect any reception. It made a nice change to be more impressed than I expected to be rather than less impressed.
Post #824398 10th Apr 2020 1:30pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I am using the Naka aerial for AM/FM only, without power (in hilly Cumbria). It's noticeably better than the factory aerial was. On the school run, my wife's Disco loses signal at several points, but in the Landy the Naka aerial gives me uninterrupted reception.
Proof that the Landy is better than a modern vehicle and more reliable. Wink
Post #824403 10th Apr 2020 1:49pm
Factory aerial was terrible I found, barely find an FM station or two and would lose signal. $W33T $0U7H3RN $UG4R
Post #824406 10th Apr 2020 2:10pm
