Home > Wheels & Tyres > Larger tyre size on a standard 90
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Larger tyre size on a standard 90.
I have bought a 90 with special track tyres on it. I want to keep them but would prefer to have something else for daily use. The truck is unlikely to do more than 2000 miles a year, though half of that will be up dirt tracks to an old quarry. (And if this virus thing keeps going on it will probably be more like 200!!)
I am likely to go for some ATs but want to know what size I can go up to on a standard truck without any modifications. I have tried searching, but the threads I have found all refer to lifted vehicles and I don't really want to do that.
I have a set of 7J R16 Freestyle alloys to put them on.
Your advice is greatly appreciated.
Regards
Mick
Post #824001 8th Apr 2020 5:05am
jst
255.85r 16 with a little rubbing on articulation. (33")
235.85r16 or 265.75r16 would be standard fitment size, these sizes work well for 99% of time and use. (31") Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #824011 8th Apr 2020 6:42am
Mossberg
Many thanks James, I appreciate your help.
Regards
Mick
Post #824077 8th Apr 2020 12:35pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
If you're only doing 2000 miles a year why wouldn't you just leave them?
I used to change wheels around two or three times a year but eventually it just becomes a faff and you give up! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #824129 8th Apr 2020 3:57pm
London 52
United Kingdom 2005 Defender 90 Td5 CSW Belize Green
Hi Mick,
235/85/16s on Freestyles
Don
Post #824142 8th Apr 2020 5:17pm
Mossberg
Hi Don,
Thanks for that. They seem to suit the truck well.
The freestyles I have now look ok on the truck but the front caps wont fit. Do I have a different wheel or do you have spacers or magical centre caps?
Thanks again.
Mick
Post #824176 8th Apr 2020 7:46pm
London 52
Hi Mick,
I had the same problem so fitted 30mm Hubcentric Spacers Thumbs Up
Don
Post #824179 8th Apr 2020 8:18pm
London 52
Couple more photos Mick to give you an idea what they look like with spacers Thumbs Up
Don
Post #824181 8th Apr 2020 8:22pm
Mossberg
Hi Don,
Thanks again pal, I appreciate your time replying.
I have heard mixed reviews on spacers. Some say don't do it as it puts the offset in a manor that increases strain so buy wheels with correct offset, but I thought that would put the same strain on the same parts - but then I am new to this so I welcome the feedback from people.
Also, how do you go on with insurance with spacers?
ATB
Mick
Post #824182 8th Apr 2020 8:22pm
London 52
Hi Mick,
I always update my insurance company with any changes from standard spec. I've recently just had a Alive Stage 1 Remap which i declared with no increase in premium at the moment plus the change in wheels with spacers were also declared.
To be honest, it's just not worth taking a chance if the worst did happened!
Don
Post #824184 8th Apr 2020 8:30pm
c_eilersen
Denmark 2006 Defender 90 Td5 ST Tonga Green
255/85 without rubbing - 285/75 with minor rubbing, which you can prevent with the steering/turning radius adjustment bolts.
Post #824195 8th Apr 2020 10:13pm
I run 255’s with no spacers and lock stops adjusted as mentioned above.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #824196 8th Apr 2020 10:18pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Done over 100k with spacers fitted and not replaced any wheel bearings
Just saying Thumbs Up
Post #824222 9th Apr 2020 9:14am
The effect of wheel spacers on hub bearing loads CANNOT be any different to the effect of running wheels with the same resultant offset, so the myth that they do is just that, a myth, uninformed piffle which has gained credence as a result of the Internet.
The effects of spacers, different offset wheels, or tyre size changes on hub bearing loads will depend on many factors but unless you go to absurd extremes is likely to be negligible. For example 30mm spacers will load your bearings less than a fat passenger.
I have long maintained that good-quality, properly-designed spacers fitted correctly are entirely safe. I think that the reason that spacers generically seem to have a bad reputation is a result of the hooky antics of the 'slammed and rimmed' boy racer brigade.
it's one of those things where inevitably someone's neighbour's cousin's friend knows someone whose spacers failed, but nobody actually knows of a genuine failure. Rolling with laughter
Post #824237 9th Apr 2020 11:04am
From what I've read spacer failure has been caused by lack of basic mantence I.e. Not checking that they are secured properly - no different to the wheel nuts.
It's only the fact there is twice the chance of this being an issue that causes it.
(Should these people even be driving which such poor maintence levels? Shocked )
I personally prefer not to use them, but each to their own. Very Happy ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #824252 9th Apr 2020 11:27am
