Home > Maintenance & Modifications > Front hub and stub axle confusion
mini Anaconda
Somewhere along the line my Ninety has been fitted with what I believe is an early Disco 1 front axle, I have come to this conclusion because the drive flange has a little stubby drive shaft attached to the inside of it.
I need to replace the hub and also the stub axle, I think the part numbers are as follows:
Stub axle - FTC57 (available also in BP kit DA3193)
https://www.paddockspares.com/stub-axle-ki...o-ja0.html
Hub - FTC1457 which seems to be VERY expensive £406!
https://www.brit-car.co.uk/product.php/864...er_classic
Can I use the correct stub axle (FTC57) and a different hub?
For example this one below
https://www.paddockspares.com/ftc942-hub-assembly.html
Or is there another way round it all?
Many thanks. BORG - Bucks & Oxon 4x4 Response Group
Post #823533 5th Apr 2020 8:04pm
jst
Rrc. Had short stubs, didn't know d1 did?
Why does hub need changing? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #823578 5th Apr 2020 10:32pm
mini Anaconda
My research shows the early Disco I had the same hub arrangement.
The inner bearing race looks like it has been spinning inside the hub, a new race (and original) can be pushed in and out of the hub by hand also the stub axle shows sign of wear and damage. BORG - Bucks & Oxon 4x4 Response Group
Post #823608 6th Apr 2020 8:05am
mini Anaconda
Bought some 2nd hand ones from a nice bloke on Ebay, two hubs, stub axles and stubby driveshafts for £50 delivered.
All in very good condition so I am happy.
Just for info you can buy the stub axles new but not the hubs.
Thanks for the replies. BORG - Bucks & Oxon 4x4 Response Group
Post #830907 13th May 2020 4:50pm
jst
Cool, good result Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830947 13th May 2020 8:04pm
