![]() | Home > Technical > Defender lights out....it’s not the switch! |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Have you checked all the fuses for the headlights.? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
barkingmad Member Since: 02 Feb 2014 Location: ashford kent Posts: 8 ![]() ![]() ![]() |
Hi Richard, thanks for the reply
Yes, I have ..they’re all ok, sorry I should have mentioned that in the post |
Is headlamp relay working ( under dash second row from top right side )
![]() fuse 15 5 amp supply to relay coil and other thing too ![]() fuse 15 is feed from ignition switch and post 07 defender have trouble with ignition switches Last edited by dorsetsmith on 5th Apr 2020 10:15am. Edited 1 time in total |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1772 ![]() ![]() ![]() |
With everything connected as normal, and with the ignition on, measure the supply voltage at the headlight connector, then turn the switch on and measure again. I have/had a fault where one of the connections had gone so high impedance that it showed 12V with no load and instantly collapsed under any load!
