Home > Technical > Brake Query |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
hmmm, you have sucked air back in the pipe.
i would just bleed the whole vehicle and that would change the fluid as well - quite quick and simple. BM52 |
25th Jul 2011 9:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Wheel bearing???
Start with a pad check, then a bleed. You could use a pipe clamp on one flex pipe at a time, to check the different calipers. Andy |
25th Jul 2011 9:46pm |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
Thanks guys, I am going to look at both Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
28th Jul 2011 12:05pm |
