Home > Td5 > Squeaky seats |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 105 |
Hello, my 90 TD5 developed quite noisy squeaky seats, probably the springs... As I have not become any heavier and don't plan on getting any lighter , does anybody have a solution to the squeakiness?
Best Alex http://instagram.com/h4vou/ |
31st Mar 2020 6:59pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Check that something isn’t broken. There are no springs in the seats.
31st Mar 2020 7:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
It could be the seat back squeaking on its pivots.
31st Mar 2020 9:20pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Drive slower..... well it is the 1st April!!!! Cheers Don.
1st Apr 2020 8:35am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 714 |
I'll be interested to hear how you get on with this, my driver seat squeaks when you lean back hard and the passenger base squeaks on every pothole/minor bump but only with a passenger in it, it's something I've been mean to fix for a while. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
1st Apr 2020 12:47pm |
Check bolts are tight.
1st Apr 2020 1:03pm |
Turn the stereo up...... I am not helping am I Cheers Don.
1st Apr 2020 2:50pm |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 268 |
Try taking one bolt out at a time but replace before removing another Hopefully find the squeak by elimination
1st Apr 2020 3:02pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 934 |
In my experience a squeak in a seat is usually the pivot area in board side near the cubby box. There is a spring there and it often moves ever so slightly and begins to creak metal on metal. Check it out and lube it but don’t use WD40 it is not good for this application as it is too thin. You can see the bottom of the spring (the tiny vertical bar under the horizontal pin). The other end goes up the side of the back. You may have to pull the upholstery to get at it there.
Good luck. Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
1st Apr 2020 3:25pm |
Sorry I could not hear any advise because of the noise and the radio too loud...
Just joking... god bless this forum and WD40... It was the hinge at the bottom of the back of the seat... both of them. Thank you! Alex http://instagram.com/h4vou/ |
3rd Apr 2020 12:27am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
give them a bit of copper Grease, or some chain grease. WD40 I think doesn't really cut the mustard at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
3rd Apr 2020 12:33am |
