![]() | Home > Td5 > Intercooler shootout |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I fitted the BAS intercooler to my (BAS 170 remapped) 2.2 and it made no difference at all to the performance, but then it's there to provide better cooling, not more power, so I didn't expect it to.
However it opens the way to an uprated turbo which will give more power, so that's the main reason I got it. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Very informative, but it lacks the dyno numbers. Can't leave well enough alone
I did some calculations and for every 10C the inlet temperature will go down you get about 3.4% more air in your cylinders.
The question I have been asking more often how much does an uprated intercooler cool more? Normal driving with my standard intercooler I have about 40 C at 100 km/hr. Working hard say with trailer up hill etc it gets upto 60-65 C depending on the outside temp. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
If you’re measuring coolant temperature, A tdci goes over 90.
If you are just lookin to drip the charged temp, get a water meth injection system. Get the one with the egt probe so when you are towin it helps cool the charged air as well as the exhaust gases. I went for performance, and currently runnin 2gph nozzle for light loads, mpg, and 3gph power for when i am heavy on the throttle. So far its all workin nicely, and my egts with a remap are around 1250f which is the absolute max. Can't leave well enough alone |
Coolant is a different thing. My Coolant temp is between 88 and 92 C and fluctuates depending on how much it has to work but reacts slowly. Airintake temp reacts very quickly in a few seconds you see it decreasing or increasing depending on your throttle position. I am interested to know how much better a better intercooler cools. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
There are a few graphs on the BAS website.
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
Have you tried the PWR one ? Only available thru Ian @IRB Developments. We did a lot of R&D back in the day when i was there. A well proven intercooler used by a fair few of the BTCC/WRC lot... Putting Dreams on Drives at JLR Solihull..
