![]() | Home > Puma (Tdci) > Alarm volumetric/interior Protection Sensor |
The volumetric sensor is a little lozenge-shaped thing set into the trim above one of the B posts (it's UK drivers side but I don't know if it's handed for LHD vehicles.
It should be set by default if locked with the fob. It's possible to lock the vehicle without arming the sensor by locking with the key. The easiest way to test it is to lock the vehicle with one of the front door windows open and then wave your arm inside. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
idiots.
If you have the sensor you can clearly see it above b post https://www.lrworkshop.com/de/connectors/defender-2007/C0719 |
Martin 911-87 Member Since: 09 Mar 2020 Location: Sweden Posts: 12 ![]() ![]() |
Thanks for your fast reply Darren!
I'll check to see if I can test it. Brgds /Martin |
Not very nice attitude macfrank!! You seams to be very experienced - so is it possible to install a sensor if it isn't installed , and is the wiring already behind the side-wall? Hope you get well soon. Brgds /Martin |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Agreed, if you didn't mean to come across as insulting macfrank then I'm afraid you have.
I'll give you the benefit of the doubt for now as you may have been referring to the intruder? ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17722 ![]() ![]() ![]() |
Hopefully the "idiots" referred to the people who broke the window, not the forum members!
hoffe nur, dass du nie Hilfe brauchst |
This is the one on my double-cab, remember the roof trim is different on an SW or USW due to the Alpine Light window.
The photo is taken from the front passenger seat looking backwards over the drivers seat, it is a right hand drive vehicle. ![]() Click image to enlarge |
Thanks for the picture blackwolf!
I definitely do not have it installed. I will try to find out if it is possible to install one. //Martin |
you will need to check for small black plug( A )and wire going to gray plug passenger side ( B ) up under head liner just back for a pillar loon may not in place
![]() Click image to enlarge Last edited by dorsetsmith on 31st Mar 2020 5:03pm. Edited 2 times in total |
sorry guys! my grammar! OF COURSE with „idiots“ I meant the scumbags who broke into the car!!
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Martin 911-87
Welcome aboard... just to add to the advice so far, I wanted to check mine prior to purchase and on the advice of a specialist who checked the vehicle I was told just to sit in the car, arm it via the fob and the intruder sensor then becomes active (from memory) 15-20 seconds after the fob is pressed, so if you get no alarm immediately...wait... then wave your arms around ![]() Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
[quote="dorsetsmith"]you will need to check for small black plug( A )and wire going to gray plug passenger side ( B ) up under head liner just back for a pillar loon may not in place
Thanks dorsetsmith, much appreciated! There is a recess behind the fabric in the ceiling panel at the location for the sensor. I will check if the cables are there. Are the wiring routed from the floor up through the B-pillar or from the A-pillar via the roof panel above the side window? //Martin |
Hi macfrank, It came across a little bit blunt Sry. for my misunderstanding - I'm also nice ![]() //Martin |
