Home > My Defender > Matilda The TD5 90 |
TheMule Member Since: 08 Mar 2019 Location: Norfolk Posts: 41 |
Thanks Harry.O is yours remapped? Due to the virus mine had been postponed until further notice unfortunately Thanks Jim I think I’ll have mine done as a precaution before the remap and use the longer allisport supplied studs! |
28th Mar 2020 10:49pm |
I did the Series light surround and different grill on mine. Because there are several large holes in the front wing panels on later models, I also modified and kept the original light surrounds and painted them in body colour. The grill is a powder coated stainless one from Lockwood International. Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Mar 2020 8:25am |
I like the Lockwood grille too, it’s a toss up between that and a heritage one! I really like the look of yours, so td5’s have the same number of holes in the front wing or is it just pumas? Yours look great by the way LandroverAnotak
29th Mar 2020 9:13am |
Yeah, I think so. Apart from the hole for the horn, there's another set of holes below the headlight aperture. It's never been clear what they may have been intended for:
29th Mar 2020 9:27am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 |
Many people think the redundant holes below the headlight (not present on all models/years) are for washer jets, but they don't actually bear any resemblance to the holes needed for Defender headlight washers! Bit of a mystery really.
29th Mar 2020 9:32am |
Hmm interesting, I can’t say I’ve seen that lower hole before on mine ? If not then I’ll have to trim the original panel down and then put it behind the series headlight ? Thanks for all the useful replies
29th Mar 2020 9:54am |
That's exactly what I did - you have to cut the 'rim' off the headlight aperture for the Series bezels to fit. You can buy ready made panels from the likes of Nakatanenga and Offroad-Tec but I refuse to pay £150-odd for what are basically flat panels with some holes cut in. I've got half and idea to make my own at some point but it's not high on my priority list. Darren
29th Mar 2020 10:04am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
All of the extra holes are only present in Pumas I think. My Td5 wings are both plain under the headlight finishers apart from the horn holes 2002 90 Td5 Station Wagon
29th Mar 2020 11:47am |
Thanks grafty
I’ve nearly finished cleaning them up, they’re really very straight and will be sprayed with etch primer and then painted body colour ! Grille wise I’m thinking this being body coloured too ? Click image to enlarge Click image to enlarge |
29th Mar 2020 7:05pm |
The grilles come gloss black so you could try it on in black before painting it 2002 90 Td5 Station Wagon
29th Mar 2020 10:00pm |
Sorry, you're right. I just dug out a pic of the bare headlight aperture on my old '05 TD5 and the panel is plain except for the hole for the horn. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Mar 2020 10:32pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Hi, yes it's a stage 2 map from Alive. Mine didn't seem badly warped but 2 of the studs had snapped in situ and exhaust soot was evident at the back of the engine. From memory I fitted the new manifold with Wurth studs (eBay) and drilled the holes on each end of the manifold a touch bigger so that it could potentially expand when hot. No idea if there is any truth to the last bit but it's not warped again is is subjected to high EGTs quite regularly Look forward to seeing the new headlight surrounds on, quite fancy turning the front end of mine into something similar to LRA's 110 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
31st Mar 2020 2:55pm |
The weather has been rather nice so have started to paint the light surrounds. My first attempt at painting anything so don’t look too closely ! Used 2 coats of etch primer and so far have managed to apply 2 light coats of Caledonian blue
Click image to enlarge Click image to enlarge Click image to enlarge I found my mothers green house to be the perfect spray booth much to her disgust ! |
7th Apr 2020 7:35pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Great work!! The painting not winding tour mother up! James
7th Apr 2020 7:41pm |
