Home > In Car Electronics > Twisted Switch Panel Installed |
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 |
Thanks macfrank,
I suspected that the connector was for the head light leveling switch but wanted to make sure. There's probably a way to do the same on a CAN bus car but you'd need to be more of a hacker than electrician. I've tested the JVC unit and you can now do most of the stuff that required the hand brake to be engaged. However, if you try to scroll (call history, play list, contacts, etc.), you'll get a warning to keep your attention on the road after 3 swipes of the screen. So even the passenger cannot use the screen without some restrictions. |
12th Mar 2020 8:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
If grounding the handbrake wire doesn’t work you need a micro pulse bypass.
(Only for use when parked up for safety.) It uses a dual live pulse modulation which will correct any issues with features being locked on the HU. However, it may not work with head units with in built Sat Nav. Kenwood used to just need grounding, JVC is in the Kenwood group. Pioneer and others need a bypass or connecting as per manual details. It is designed to be like this for safety but in real world situations it can actually prevent you from using features that are actually required with aftermarket fitted items. A bypass then means you do not need to cut into wiring either which not many want to have to do that either. Obviously you heed safety and only use these features when parked but prevents having to mess around with the hand brake wiring. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Mar 2020 9:04pm |
Nadine90 Member Since: 07 Jan 2018 Location: CAERPHILLY Posts: 49 |
Defender upgrades have the panels without the hole
12th Mar 2020 9:35pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17463 |
^^^^ So they do, many thanks for pointing this out.
Quite a bit less expensive than Twisted too. |
13th Mar 2020 9:41am |
I've noticed another issue now and searched the forum to see if anyone faced it before without success. When using the mic for hands-free calls, people are complaining from clicking noise. I've figured out that it is related to the vibrations from the engine and gear box and if I remove the LR mic from the stock location the noise stops. I also tried the mic that came with the JVC unit and the noise is there. So I opened up the steering surround and used some cloth harness tape to try to reduce the clicking noise but it did not help.
Click image to enlarge Click image to enlarge I've tried to tidy the wiring inside but people are still complaining from the clicking noise. Click image to enlarge I also noticed that the steering is rubbing against the plastic trim. I think it is not affecting calls but I am having second thoughts now. The same steering wheel was installed with the original alpine unit and no one complained about the noise during calls. Click image to enlarge Do you think I am chasing the wrong end? I doubt it is related to the head unit since when I remove the mic from the steering surround the noise stops. Any thoughts?
It's good we have more choices now. I've ordered from them before and looked on their web site before I got the twisted panel. They did not have it at that time. It also can take 8 switches compared to the 6 switches of the twisted panel. |
13th Mar 2020 11:08am |
I've ordered a DU panel and will report back to the forum when it arrives.
13th Mar 2020 1:55pm |
Headlamps leveling! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Mar 2020 10:41pm |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 |
Can @Siglo or anyone confirm if the Twisted panel requires the same size hole in the dashboard as the ebay/Mud style??
I have the panel with the round hole in but would love to change to the Twisted panel if it is going to fit in my existing dashboard hole. 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
28th Mar 2020 10:18am |
The twisted panel is smaller. You can see in the below photo that I am using the metal template that came with the mud unit as a guide for my dremel. It made it easier to cut straight lines. The metal template for the mud panel is considerably bigger than the opening required for the twisted panel.
Click image to enlarge |
28th Mar 2020 10:58am |
I don't know about the Twisted panel, but the Defender Upgrades panel (the one for 8 switches plus Hazard) requires a hole 78 mm wide and 180 mm top to bottom, +/- a couple of mm.
I'm quite impressed with the DU panel, it's not bad at all. |
28th Mar 2020 11:04am |
In case anyone is interested, I found a screen protector for the JVC unit on Amazon UK.
It might not be useful to everyone, but with the amount of dust we get here it is good protection for the screen. I should have fit it more centered, I started on the silver edge of the right side and ended with a small gap on the left. Click image to enlarge Click image to enlarge |
7th Apr 2020 6:15pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3326 |
Mine had similar interference when mounted there. It was recommended I moved the mic up to interior light and it's now perfect. WARNING. This post may contain sarcasm. |
7th Apr 2020 6:34pm |
silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27 |
Sorry to bring up an old thread but can I ask how people secured the side panel?
I’m doing the job tomorrow and read lots of problems getting them to fit. I’ve gone for the du 8 switch plus hazard, I thought the tabs on the side would be deeper to grab the back of the dash. Cheers |
2nd Sep 2022 10:14pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3684 |
Are you using a twisted side panel or something else? If twisted, it has a rebate right along the top and two spring clips on the bottom. You don’t need to do anything other than cut the hole to the right size, slide the top section in and then push the bottom section until the spring clips click.
You will need to cut away the supportive webbing on the plastic on the reverse side of the dash to make room for the rebate and clips, but this can be done very easily with a sharp Stanley knife. |
3rd Sep 2022 7:01am |
