![]() | Home > My Defender > New chassis 300 tdi 90 |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Additional work identified so far:
Swivel seals ![]() Steering box leaking ![]() Click image to enlarge Spring/shock fittings ![]() Click image to enlarge 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
Thank you for posting the 90 and the progress pic's
![]() Has the 90 got it's original engine in still ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Washed and ready to start.
![]() Note. I had removed grill, radiator, engine electrical connections and plumbing. Radiator just loosely refitted for transport. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
No, it was a turbo diesel soft top when new. One of the last civilian soft tops for U.K. market and one of the first turbo diesels. (1987) 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
That's a pedestrian-friendly bumper!
Custom built, same fittings on rear. Takes a discountable hydraulic winch, or a variety of tow hitches. Secured with tractor implement pins. 80" 1948
Sorry but i didn't read your title thread properly
![]() but thank you for the information on the 90 ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5262 ![]() ![]() |
I am surprised that the galv chassis has gone! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Ah, I remember now, you mentioned this before. A very neat arrangement. How old is the failed chassis, and was it a new chassis supplied galvanised or a repaired chassis that was then galvanised? |
The chassis that needs replacing was a ‘chassis for life’ fitted by Foleys. They claimed or was a new galvanised chassis, but the plain factory chassis it replaced had lasted longer!
That is another story, and my dissatisfaction with Foleys was well documented on another thread a while ago. This thread will concentrate on the re-build, not the reasons behind it. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
The term "chassis for life" would take some explaining under the circumstances. The story is coming back to me now.
My sympathy for your hassle, but you will get a much better vehicle as a result. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
never seen shock brackets corrode like that..i know you live by the sea but that looks like you have parked in the harbour for years.assume you launch / recover boats with it ?
should be a good rebuild. plus all the maintenance jobs that you never get time to do will be done for you and it'll come back driving like a good one. are you going to put any extra coatings on teh chassis this time with were you live as now would be teh best time to do it? |
I live about twelve miles from the coast, it has never been into the sea. Still undecided about additional coatings for the chassis. Like everything, cost is a factor! 80" 1948
they must use some grit up your way then thats worse than any lr ive had from Scotland before.
i would be adding some more protection to that or washing it more often |
