Home > Td5 > nnn ecu in a 10p engine |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
My NNN500020 ecu appears to have failed in my 10p engine with a 3197 code - topside switch logged as failed pre- injection found using a Hawkeye
picture shown shows what is rust on the nuts and the surface of the board has a sheen to it - anyone seen this before the ecu is dated 2017 Does anyone have a spare working ECU around the Cheam area that could be tried before mine is sent off for repair. have an hawkeye to code the injectors but havent done this before Click image to enlarge |
22nd Mar 2020 4:18pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 617 |
Corrosion on the nuts is not a real problem. These nuts are just holding the capacitors. Problem is corrosion on the rest of board and on the other components. Lot of time it is possible to repair the ECU. I did it several times.
Remove also the bottom cover and look for any burnt or corroded component. Look carefully also on the power components mounted on the side walls. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
22nd Mar 2020 8:24pm |
