Home > Technical > Parasitic load I think |
Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 78 |
Should have explained myself better.
If the diodes in the alternator have gone, then the alternator will draw back out of the battery, therefore you can measure the load with the alternator connected and disconnected, or leave the car with the alternator disconnected to see if this solves the issue of it going flat |
14th Mar 2020 9:04am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Aha i get you, i didn't realise that could happen, i will try that thank you
I am planning on an expedition to Morocco this year (Virus permitting!!?) i might buy a new one and have this one recond as a spare, what make is the Genuine? there's loads listed as options 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
14th Mar 2020 9:16am |
Genuine (original) is Varta 90Ah
7H42-10655-DA YGD500160 I still use mine (9 years old) for heavy duty 12v stuff in the garden etc. I currently run 2 Odysseys with Blue Sea split management. Never had an issue. MobileCentre kitted me out Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th Mar 2020 9:35am |
Sorry I should have been a bit clearer, I meant the alternator.
In fairness my original battery lasted a good 8 years I did a lot of research and settled on the National lunar set up, I planned to use Odyssey’s but a red and yellow top Optima came up at a good price. I might just bite the bullet and buy a new alternator and an odyssey 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
14th Mar 2020 11:36am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 623 |
Try to load the battery with some ligh bulb, like H4. The voltage with this light on, should drop approx to 11,5V, but not to 10V. Or just reconect tha battery in car, switch on lights and measure the voltage. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
14th Mar 2020 12:23pm |
Thanks for all the advice chaps
The problem is the Red Top Optima, its loosing charge and getting excessively hot when on charge via the ctek or the alternator. Problem solved Trouble is i need to spend out on a new battery, i have heard very good things about the Odyssey so that's the direction i am going. Thanks again 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
20th Mar 2020 1:19pm |
