Home > Technical > Propshaft question
dioliahary
Propshaft question
Replaced the front, manual says sliding parts should be at the front near the axle...but my old one had the sliding part near the transfer box. I have followed the manual, any thoughts or pearls of wisdom. 1990 200tdi conversion 90
Post #819066 10th Mar 2020 8:25pm
MartinK
This help?
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #819122 11th Mar 2020 1:05pm
Retroanaconda
That looks like a Series III parts book diagram.
Reality is it doesn't really matter. I've always put the slip joint at the transfer box end but it makes no difference.
Post #819128 11th Mar 2020 2:17pm
Surely as the axles are lower than the T box then the joint should face towards the axle.
Then any water and debris will tend to head downwards and away from the joint.
This is one of the reasons why the rearmost UJ often fails, which is something you can’t do anything about as being low.
At the rear and the lowest point it attracts the most water ingress etc and is the most common to fail.
The front axle UJ avoids it much more because spray and water is often kicked up more to the rear.
So in effect, the Sean’s IIRC should face each axle away from the T box. TheThunder Rolls🇬🇧🇺🇸
Post #819144 11th Mar 2020 4:11pm
Mo Murphy
Sliding joint to the transfer box front and rear is what I've always done. I do it that way round on the front to prevent crap being forced into the sliding joint as it's not particularly well sealed.
50 Shades of Pennine Grey
Post #819147 11th Mar 2020 4:30pm
dioliahary
Popped into Land Ranger services today and he confirmed that it does not really matter, phew scrapped my knuckles sticking it on last night👍 1990 200tdi conversion 90
Post #819161 11th Mar 2020 6:27pm
Seals* Typo there. Apologies. TheThunder Rolls🇬🇧🇺🇸
Post #819168 11th Mar 2020 7:24pm
