![]() | Home > My Defender > Defender TD5 90 1999 from France |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Welcome Aurel, you've got some work to do there! Is the transfer box stuck in low range or high range?
Orel33 Member Since: 05 Mar 2020 Location: Bordeaux Posts: 4 ![]() ![]() ![]() |
Hello Huttopia, thank you very much. Yes a lot of work but crazy in love
![]() The transfert box is stuck on "neutral". I were not able to drive the car ![]() |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 577 ![]() ![]() ![]() |
Bonsoir Aurel,bienvenue.
Take a look at the transfer box selecter linkage,under the transmision tunnel. Was it cheap? ![]() Marc. |
Hello thank you
![]() I’ll tell you if it is Ok ![]() |
This is what you are looking for.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
Not the linkage that's circled as that's the diff lock. The high/low linkage is the one going down and back at an angle.
Of course it is......
Didn't see the red circle, ![]() Should have put my specson. ![]() Marc. |
Hello, thank you very much. I'll see this area. Have a good day
