Home > Technical > Mt82 de Puma a 300 TDI
Page 2 of 2 <12
sako243
blackwolf wrote:
I wonder what the gearing would be like with an MT82, original 1.4 ratio LT230, and a TDi engine. Low first would be exceptionally low, I'd think.
I worked this out on a long drive back from the Highlands as my 300Tdi has a 1.2 transfer box fitted to an R380 and a friend has a 2.2 Puma. I think from memory all gears map through pretty much identically 2nd in MT82 -> 1st R380 and so on. The only difference is that they've introduced a lower first to accommodate the taller transfer box gearing.
So they offered from factory a marginally better gearing setup than what people had been doing for years with retrofitting 1.2 transfer ratios. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #818273 5th Mar 2020 12:21pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
jst wrote:
An underdrive? Same price as the adaptor plate. Struggle will be finding one.
It would be ideal, but ashcroft doesn't make it anymore.
But the price soars ......
Post #818274 5th Mar 2020 12:47pm
sako243
Are you trying to drop low range as well or just high range? If the latter then what about a 1.6 ratio set from Ashcrofts? Ed
Post #818303 5th Mar 2020 3:55pm
Fernando
No, just the bass!
Post #818478 6th Mar 2020 12:25pm
jst
4.11s?
Puma, 1.2 1st is lower and 6th is higher than an r380, 1.4
Its was all.part of the original marketing blurb.
But as salon says r380 and 1.2 box makes pretty much 1st lower and 6th =5th Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818569 6th Mar 2020 10:57pm
Page 2 of 2 <12
