![]() | Home > Puma (Tdci) > Calling all DEFENDER Detectives - Mystery leak-black exhaust |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
a split in one of the air / boost rubber hoses?
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
your burning oil by the sounds of things get a mate to sit inside and press the accelerator see if is producing black smoke . any oil over the air air hose filter box any inside the air box ? clean all the oil off gunk will do it then try to locate the leak . check the coolant see if its sludge like if it is oil is entering the coolant system possibly a head gasket good luck rob
andy |
expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58 ![]() ![]() ![]() |
But what could be causing the black smoke from exhaust?
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Black smoke from the exhaust can be caused by burning oil but it is more likely to point to over-fueling. This might indicate faulty fuel injectors, sensors, or some type of issue with fuel pressure. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Interesting. Do you know if any of these things would throw a warning light. I am not getting one and it is odd.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Oil tends to burn blue, black is more likely to be over-fuelling. It could be something as simple as a split intercooler hose. It is quite likely that it won't cause the MIL to illuminate, but there may be stored DTCs which provide a clue.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
If it's going to limp mode there must be fault codes stored.
I didnt see a picture , small hose popping out? Do you mean oil feed on back of vacuum pump, ( it may be a return) Black smoke is unburnt fuel, indicating too much fuel for available air, so check air supply. Hose integrity. Without seeing it sounds like two problems. 1. Vacuum oil pipe came off, hence loss of oil and oil in engine bay. 2. Over fuelling die to lack of air, split intercooler pipe expanding releasing air at higher pressures. Any noises under boost? I expect if you drive it harder up the rev danger in lower gears it will do the same as 4 to 6th. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 550 ![]() ![]() ![]() |
Hi, is it a 2.2 or a 2.4 engine without DPF ?
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
His avatar thingy says its a 2.4, so no DPF.
