Home > In Car Electronics > Twisted Switch Panel Installed
Page 1 of 3 123>
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
I've done a double din conversion a while ago (ebay fascia) but since there are lots of threads about the double DIN conversion I did not see the need to document mine. I did not like the idea of the side switch panel with the round hole. I first thought about only adding the hazard and a couple of switches directly to the dash but wanted something cleaner looking. I emailed Twisted to see if they'd sell me their switch panel and they did. Very Happy
I currently have the ebay double DIN panel installed and I also have the new one offered by Mudstuff. The quality of the cheap ebay fascia is not that great so I got the one from Mudstuff which seems better. The side panels that came with each one cannot be compared to the Twisted panel. The way that the twisted panel attaches to the dash is far superior and worth the extra cost. You can see what I mean in the photos below hopefully. In case you are wondering why I did not get the Twisted double din panel; besides the price, I really wanted movable center air vents. It makes a huge difference during the summer over here.
The retaining tabs of the Twisted Panel Vs. ebay's and Mudstuff's
Mud's
I made a very tight template because my strategy was to start with a smaller hole and expand it as I go. I wanted a very tight fit and it took me some time to get it the way I liked.
I masked the area and marked a right angle to the best of my ability. The metal template of the Mud's unit came in handy to guide the dremel while cutting.
I was trying to be precise and delicate but the think plastic of the dash didn't want to go without a fight. It broke three of my smaller disks so I had to bring out the big guns. Mr. Green
Since I cut the whole smaller than needed, it took me some time to get the fit I wanted. I was planning to clean up the cut once I'm done but since I spent more time than I wanted enlarging the hole I left it as is.
I did not need to extend any of the wire for the button, they fit just fine.
And finally, success (Kind off, I still need to replace the crappy ebay fascia and connect the dimmer wire of the JVC unit)
I've just noticed in this photo that I forgot to set my clock Cool
Post #817774 1st Mar 2020 8:09pm
mcma1
Post #817777 1st Mar 2020 8:36pm
Sulisuli
Very useful post Thumbs Up looks smart. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #817787 1st Mar 2020 9:06pm
Looks good, I prefer that side switch panel to the one with the circular hole at the bottom.
Only thing I would say is, although you may have done this anyway.
Be sure to check that there is no wiring behind the cutting tools, there is a lot of wiring behind the dash sometimes factory or aftermarket and would cause a big headache if cut though.
The best way to do this is with the centre dash out for access, unfortunately a bit ore work but worth checking and of course measure multiple times and cut once as you did. Thumbs Up
Like the Check Temp install too in that location, was there much involved with that? WeWillWin🇬🇧🇺🇸
Post #817789 1st Mar 2020 9:11pm
PCM
Looks smart. Thumbs Up
I did exactly the same thing with the console, but using the same cutter I sliced off the silly round bit from the side console.
With a bit of black putty added during fitting you honestly can’t see the cut even with detailed studying.
I also quite like the fact I don’t have any blanks.
My son and side panel came from Defenderupgrades. Very good quality, but did have the silly circle.
Post #817792 1st Mar 2020 9:17pm
siglo
Since my defender did not come with the head lights leveling option, I just needed to cut out the space where the switch goes and fit the check temp in its place.
I thought about cutting the circle off, but I wanted the extra switches to see if I can install a rear wiper with OEM switches and relocate a light switch I have to the panel. I don't like the blanks either, but they give me room for future switches. I think I should get a winch installed now to use a couple of blanks for the controls maybe Mr. Green)
Post #817798 1st Mar 2020 9:37pm
Pickles
Top job, top post.
Thanks siglo, Pickles.
Post #817806 1st Mar 2020 9:57pm
Mine is the same without the levelling switch, I might do the same. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #817810 1st Mar 2020 10:08pm
siglo
Just keep in mind that it won't be easy to read. I mainly use it to check the temperature and I do that while the vehicle is stationary.
I've changed the location of the internal temperature sensor today as well. It used to be up in the A pillar so it wasn't very accurate. I've relocated it to shelf underneath the passenger grab handle. Hopefully it would be more accurate. I did not connect the check temp to the A/C so it's not really that important anyway.
Post #817817 1st Mar 2020 10:34pm
I really like that Twisted side panel!
Does no-one besides Twisted do one with that configuration of switches and without the utterly stupid round hole? What is the purpose of the round hole, by the way?
Can anyone tell me how much Twisted charge for the side panel on its own? (I've just seen the price of the complete double-DIN dash from twisted and it nearly made me spill my beer) Shocked
Post #817823 1st Mar 2020 10:57pm
siglo
I came across another supplier in the UK that cuts off the round part and refinishes the panel. I could not get them to sell me the panel only though. Their double DIN kit also required to cut off the part with the clock and vents from your original dash so it wasn't very appealing for me. Let me know if you want their details and I'll search through my emails and get your their contact info.
Twisted charged me £90 for the side panel, which is quite expensive for what it is, but I think it's worth it.
Post #817842 2nd Mar 2020 4:30am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I have a friend who is in the process of designing his own side panel the same as this for his landy
I think once done he is going to produce them. 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #817847 2nd Mar 2020 8:32am
pj2106
He just made these for me
Post #817848 2nd Mar 2020 8:34am
siglo
They look nice, it seems your friend must have access to a good 3D printer. I would recommend he designs similar tabs as the twisted one for the panel to fit the dash. Or even better use the same kind of torx screws that hold the original LR panel. That would look even better I think and make the installation easier.
I forgot to mention that the twisted panel needs you to clear out some plastic from behind the hole so the tabs can fit. That part was pretty annoying. I had to either remove the steering to use the Dremel or do it with hand tools. I did it with a small knife and file from a multi-tool.
Post #817851 2nd Mar 2020 8:57am
siglo
I thought I should update this thread with more info regarding the JVC double DIN unit. I've got the ISO adapter to connect it to the LR harness.
The adapter for puma is missing pin A6 (according to JVC numbering) which is used for illumination function.
I've visited a local stereo store and got the same type of PIN with cable (Orange) added to the adapter.
I've faced a weird issue with the AM/FM antenna cable. I am using the stock AM/FM antenna without a splitter and using a separate DAB antenna.
The LR antenna connector seems to be longer that standard ISO.
When I insert the antenna all the way, I lose AM reception completely. When the antenna connector is half way inserted only I get reception just fine. I will add a rubber grommet to the connector to prevent it from going all the way in and find a way to secure it to the unit so it would not fall off in the future. The JVC antenna socket looks fine to me.
Also, I found out that if you ground the hand brake lead of the JVC unit, you can use the keyboard in Android auto instead of voice commands. I did not test it while moving, but I think it should work. It was annoying to pull the hand brake at stop lights every time I wanted to type something into android auto.
I found a plug behind the dash that I am not sure what it is for. I suspect it might be for an option that I don't have (traction control, head light level, or rear wiper). If anyone knows what it is for I'd appreciate it.
Post #819167 11th Mar 2020 8:24pm
Page 1 of 3 123>
