Home > Maintenance & Modifications > Axle Strengthening/Trussing any experience? |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I'll have a set! happy to fettle the rears to fit the 110/130 puma rear axle.
I love the D44 diff guard but it doesn't look like they still produce them 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
28th Feb 2020 9:25am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8006 |
i dont think thats appropriate IF its aimed at the ref above to a very reputable supplier and contributor on here. Sleeving is pretty simple to do can can be done in home wksp with ease. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Feb 2020 9:27am |
Nigel Barker Member Since: 28 Feb 2020 Location: Costa Del Haslemere Posts: 7 |
Hiya James !
( you could ask for a group discount was aimed at .....Meeeeeeeeeeeeeeeeeeeeeeeeee lol ) and Mr Shroppy ............Keep yours eyes open then ... The product we are about to launch is "yet another bloody HD Diff Pan" .. except 8mm Domex Plate with M8 thread holes....for welding on to the axle casing after the standard pan has been cut off, and then a 5mm Plate ring with a Domex 5mm cover can be bolted into place. 5mm Domex 700MC is about the same as 15mm mild, so near bomb proof, and will come in at around £100 per end Prob 2 weeks from launch,, Nige |
28th Feb 2020 9:31am |
Any teaser photos Nige?
I'd definitely be interested in a pair along with a truss kit 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
28th Feb 2020 9:46am |
Sorry no, just vast numbers of v1 2 3 4 5 ...solidworks DXF files !
You'll just have to contain yourself |
28th Feb 2020 9:49am |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 |
Looking forward to seeing your latest product Nigel
28th Feb 2020 9:16pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
Fairly sure he posted a prototype on his Facebook page - whether it'll look like that who knows... Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
29th Feb 2020 7:52am |
Click image to enlarge customer picture to me, said fit was superb ! |
21st Jun 2020 10:27am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6090 |
Surely keeping the sides solid and not full of pretty holes would make it a lot stronger?
21st Jun 2020 3:15pm |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 127 |
No the load is carried through the edges to stop the axle from bending lightening holes are regularly used to lighten parts in aerospace industry. It’s stopping torsional twist and bending in the axle beam as long as the holes don’t cut through the edges it’s all good
21st Jun 2020 3:59pm |
Arguably if Nige dimpled the holes then they could add some strength Ed
21st Jun 2020 8:28pm |
Regardless of the relative strength merits, is it not a giant mud trap? Darren
22nd Jun 2020 7:13am |
Chugga90 Member Since: 07 Sep 2014 Location: Bucks Posts: 208 |
Be able to grow some mushrooms in it then and be a proper survivalist?
22nd Jun 2020 7:15am |
Hi All,
1st - this is made from Domex 700 MC Thats not your standard metasl - its approx 3 x structural strength of mild, so, 3mm Domex is same as 9mm plate ! but only 3mm lightness, essential for the racers. Also, this was designed using Solidworks CAD - and run through the stress analysis programme to see whats what, basically the holes make little difference due to design and metals used. The holes frankly are there to run Locker ait lines inside and or brake pipes, then give ability to blast all the crud out through the holes - and there are if you look at the pictures drain holes laser cut in the unit(s) to allow crud out Front and Rear axles set (ie Kit does front AND Rear) axles with all plates nuts bolts etc id £120 + VAT ish 120 sold so far, nobody has bent any, and some of the customers are known nut jobs ! Nige |
22nd Jun 2020 10:02am |
