![]() | Home > Technical > Cav 19j 2.5 TD fuel injector pump Advance or not to advance |
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 ![]() ![]() |
On my previous 19J 110, I set it by the book - biggest area of weakness was the diaphragm on the Injector pump having a small split in it. so that was replaced and then changing air filter regularly...
Alan S Member Since: 22 Sep 2019 Location: South Devon Posts: 17 ![]() ![]() ![]() |
Hi,
Diaphragm changed after issue with tank pressuring. K&N filter regularly cleaned and oiled with snorkel so no issue with air flow. Alan S |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
I may not be all there but in the past on my old jap pick up's, i use to have piper cross air filters and regularly cleaned and oiled them up, but i always thought it should have more oomph with a performance air filter, so one day a good friend said get rid of that rubbish and put a K & N filter on, so i did and what a massive difference, so from then on i have put K & N filters on my vehicle, but i have never oiled them and i have never had any problems them not being oiled to this date and Millie is on 376,000 now ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Hi
K&N supply a cleaner and oil for the filter. The oil holds on to the dust they claim. |
Yes you are right with the oil supplied
![]() But since i had the piper cross problem, i never put any oil on the K & N filters as i think that the materials they use are much better than the foam stuff that others use, this is only my opinion though ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
