![]() | Home > For Sale & Wanted > [Wanted] TOP "A" frame fitting brackets (edited) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
They are the bottom brackets.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
They're the bottom ones but the way they are photographed they are 90 degrees out of rotation.
The flat piece with two bolt slots goes under the bumper/bumper bolts and the narrower bit with one bolt slot goes alongside the chassis rail and gets bolted by the tie ring eye bolt > 110 XS Double Cab |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3800 ![]() ![]() |
Hello
Thanks people Does anyone have the top brackets or are these what I need> look like they could be ![]() Click image to enlarge Thanks |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
They are the top brackets, just be careful you get them handed as per the originals supplied by Land Rover. I bought a set of replacements , don't if it was from that company, they were not handed and did not fit as a result. Just had a second look at the photo, they are not the ones I bought, it may be worth giving them a call to check. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Hello
Do you mean there is a left hand and right hand bracket ![]() If so it seems to suggest they are sold in pairs so will check Thanks |
Yes, a left and right hand side same as the lower ones. If you look at the second photo, that's on the off side ,on the Flatdog site you can see how they fit, the near side is a mirror image. Don't make old people mad.
For info, my upper brackets are not 'handed' they are both identical > 110 XS Double Cab
Ben from FatDog parts got back to me..
He agreed they are not handed? "The top defender ABAR brackets are not left and right handed – they are a universal bracket- same as LR part" |
I've previously read on the forum about people having handed brackets! Mine weren't that's all.
You can see from the below pics the top brackets with both of the extended 'tang' on the right hand side ![]() Click image to enlarge ![]() |
I'm only going to add, the one I purchased from a Forum member had Land Rover sticker on the under side which had LHS and RHS on them. Don't make old people mad.
I can believe it. Wish mine had been! > 110 XS Double Cab
