![]() | Home > Technical > 13pin towing socket installation |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
Very short answer - yes!
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3660 ![]() ![]() ![]() |
I know you can get adaptors but I doubled up on mine so I have 7 pin and 13 pin allowing me to tow anything without a 13 to 7 adaptor. Hence can tow a caravan or 7 pin trailer.
Be careful to check the 13 pin kit is for a caravan if you intend to tow one and hence has all the supplies you need I brought a genuine kit and it didnt have the permanent live for the fridge, charging and ATC, so ended up selling it on and getting a maypole kit and splicing into the 7 pin loom and using the purple permanent live and a VSR for the caravan supplies, same applies to a horse box you may want internal lights etc fed from the LR DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Same advice as LR90XS2011. Defender 90XS SW
The genuine LR kit LR005919 does have the permanent and ignition feeds.
Source: there’s one fitted by me on my 2.2 90 ![]() ![]() ![]() |
Excellent thanks Martin DEFENDER 90 TDCI XS,
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 641 ![]() ![]() ![]() |
Thanks should make it a reasonably easy fit
